Beam Connection - Fixed or Pinned
We are debating this in the office. I am designing frame that will be constructed as shown on the attachment. My question relates to how to treat the connection. My coworker is saying to treat the connection between the perpendicular beams as a simple connection (ie no moment transferred to the bottom I-beam as a torsional moment), but my gut is telling me that this isn't conservative. I don't expect the top beam to develop a full fixed end moment at each end, but I expect there to be some moment capacity that then develops a torsion in the bottom beam. My reasoning for this is that if this connection detail were used for a cantilevered beam, anyone would assume full moment transfer to the bottom beam and design for torsion.
I realize that no connections are ever perfectly simple or fixed and that certain assumptions have to be made regarding moment capacity. Therefore, what is considered prudent in this situation? I could take a WAG and assume a percentage of FEM is resisted by the end connections.
RE: Beam Connection - Fixed or Pinned
Pinned and don't worry about any torsion in the supporting beam.
The cantilevered beam is infinitely stiffer to take moment in its strong axis direction than the top flange of the lower beam is to resisting the torsion. Seems like any imparted torsion would be quite small indeed.
Everyone else, thanks for the help. You all confirmed my hunch that this is normally disregarded. It's good to sometimes revisit fundamental questions like this to validate assumptions.
Dik
BA
