Change Positioned Sketch Orientation using VB
If I wanted to programmatically change the orientation of a positioned sketch - the equivalent of "Reverse V", for example - how would I do this?
This functionality does not seem to be exposed in the API. At least, I cannot record a macro of this process.
THank you.
THank you.
RE: Change Positioned Sketch Orientation using VB
