Orifice meter runs
Orifice meter runs
Orifice meter runs
Does anyone know of any issues regarding using an orifice on a 1" pipe run for gas measurement? They want to weld on some 1" flanges on the 1" pipe and place an orifice between.
Please let me know your thoughts.
Thanks!
RE: Orifice meter runs
Flanges usually aren't a problem since they have a line-size opening (or larger). Just make sure you have the proper runs of straight pipe both upstream and downstream as specified by the orifice plate manufacturer.
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
There are commercial orifice flange unions, predrilled and tapped for the standard 1 inch upstream/downstream taps for impulse tubing.
Usually come with a jackscrew, too.
API 14.3 (AGA 3) says that their calculations and standard dimensions cannot be used below 2-inch. Daniels and others sell a 1/2-inch and 1-inch unit, but they don't claim that these units satisfy API 14.3 (you have to read their material really closely to catch that). Bottom line is that for custody transfer a 1-inch meter will violate the contract that says "build in accordance with API 14.3/AGA 3". For engineering data it is probably fine as long as the accountants don't get involved and start using the numbers for something regarding a regulation or a contract.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
