Motor Horsepower/Kw for a Pump
The pump name plate is showing pump input 18.5 kw. What kw motor to be connected??? What if I connect it with 18.5 Kw motor.
The pump is for water service with details as - Q=100 m3/Hr and H=50 Mtr RPM 2940
RE: Motor Horsepower/Kw for a Pump
P(kW)=9.81*H(M)*V(m3/sec)*SG(1.0)
The 18.5 kW represents an efficiency of>70%.
It also doesn't seem to include end of curve operation so an 18.5 kW motor is either right on the limit or could trip if you operate beyond 100 m3/hr
I would go for 25 kW motor myself.
Johnny Pellin
Correct, and that was my point. If the calculated theoretical value for pumping power is 13.625 kW, then after accounting for efficiency losses, 18.5 is probably OK.
