TX I-Girder Top bars
Tx prestressed Girder.
Contractor wants to replace the Top T-bars (4)- #4 bars on Tx40 girder with 1/2' diameter strands. Saying it helps on their production process. I did not see related Tx dot Documents to permit the replacement option.
Any Bridge Engineering has similar experiences? what you suggest or share your opinions.
thanks.
McGill
RE: TX I-Girder Top bars
Keep in mind a 1/2" diameter strand does not have the same cross-sectional area as a 1/2" diameter rebar.
I'd personally be against it regardless of whether it was the same area of steel.
Professional Engineer (ME, NH, MA) Structural Engineer (IL)
American Concrete Industries
https://www.facebook.com/AmericanConcrete/
I would think a 1/2' diameter strand had a pretty big cross section, but maybe that's just me.
Quote (10p)
Hah!
I've seen it done (presumably for the same purpose, prevent top flange cracking prior to service). So I wouldn't say it is crazy... But that may not be enough justification to permit it here.
