Reinforcement for Pad footing
Hi Guys,
I've got a pad footing, 600length x 600width x 600depth, and i'm not quite sure how to reinforce it. It's taking about 10kn.m of moment. Initially i was just thinking to put slab mesh on each side to take the tension forces generated but figure it might be a bit hard to construct. Any advice would be much appreciated.
RE: Reinforcement for Pad footing
This is structural 101. Perhaps consult with your supervisory engineer?
Or hire an SE.
Your first problem is that your block of concrete is incapable of resisting 10 kN-m overturning. Get some help.
Close Box
Join Eng-Tips® Today!
Join Us             Close
