select by entering tag number or entity number ?
I dont know if this has been up before or not. Difficult to search .
anyhow, i can read in my NX logfile that either :
"entity[58611] blablabla"
or
"blablabla body (tag: 39539)"
has something wrong .
something is obviously wrong with entity xx or tag yy
now i am curious on which these objects are, can i somehow select entity [58611] or body (tag: 39539)to see which object it is ?
In this particular case i suspect either directly imported solids, or wave linked imported bodies.
one of the messages i receive is "ZERO MASS BODY encountered during weight calculation".
In reverse, if i select a solid body ( select using quick pick, then last line "solid body" and then Ctrl+I, NX will report the tag number.
But, i have some +7500 bodies in this assembly...
Tomas
or
Tomas
RE: select by entering tag number or entity number ?
The journal below will allow you to enter a tag number and it will report the object type, the object layer, and it will zoom in on the object. The object will not be selected, but there is a line of code that you can un-comment to highlight the object. The highlighting will probably stay until you use part cleanup to "remove extraneous highlighting". Entering random numbers probably won't end well...
CODE
Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Module Module1 Dim theSession As Session = Session.GetSession() Dim theUfSession As UFSession = UFSession.GetUFSession() Dim theUI As UI = UI.GetUI() Dim lw As ListingWindow = theSession.ListingWindow Sub Main() Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "NXJ") lw.Open() Dim myTag As Integer Dim answer As String = "" 'loop until there is valid input Do answer = NXOpenUI.NXInputBox.GetInputString("Enter an integer tag number", "Tag?", " ") 'if cancel is pressed, exit sub If answer = "" Then Exit Sub Loop Until Integer.TryParse(answer, myTag) lw.WriteLine("entered tag: " & myTag.ToString) Dim myObj As DisplayableObject Try myObj = Utilities.NXObjectManager.Get(myTag) Catch ex As NXException lw.WriteLine("NX error: " & ex.Message) Return Catch ex As Exception lw.WriteLine("error: " & ex.Message) Return End Try myObj.Unblank() Dim stateArray1(0) As Layer.StateInfo If (myObj.Layer <> 0) And (myObj.Layer <> theSession.Parts.Work.Layers.WorkLayer) Then stateArray1(0).Layer = myObj.Layer stateArray1(0).State = Layer.State.Selectable theSession.Parts.Work.Layers.ChangeStates(stateArray1, True) End If lw.WriteLine("object type: " & myObj.GetType.ToString) lw.WriteLine("layer: " & myObj.Layer.ToString) theSession.Parts.Work.ModelingViews.WorkView.FitToObjects({myObj}) 'myObj.Highlight() lw.Close() End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image immediately after execution within NX GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately End Function End Modulewww.nxjournaling.com
This is wonderful. I can now find the foul objects.
Tomas
