suitable Face for my core of the sandwich
Hi All,
I have to do a four point flexural test for sandwich
I have to find a suitable Face for my core of the sandwich.
I am to choose one of these three choices:
first selection: 2 layers 0°/0°
second choice: 2 layers 0°/90°
third choice: 2 layers -45°/45°
I am for first choice(0°/0°), because Faces can only be loaded under normal stress!
am I right?
am I right?
RE: suitable Face for my core of the sandwich
Your query about facings being loaded under normal stress makes little sense to me; yes, the facings are under only longitudinal load. The loads across the facings are purely from Poisson's effects.
we do this test to measure deflection and bending strength of sandwich.
my material is not woven, but is a UD-fabric (I don't know what it is called in English, see Attachement).
how will it look like when I work withClassical Lamination Theory and calculate modulus of elasticity(E1) for each face layer?
thank you again for your Help and Time
UD stands for UniDirectional This is a fabric where the majority of the threads run in one direction.
B.E.
You are judged not by what you know, but by what you can do.
I would say that choice one or two would work but I would go with 0/90 because all zeros tend to split very easily and this could introduce an unexpected failure mode.
Your advice was correct.
I did the experiments yesterday.
I have produced all variants, 0°/0° is the best variant
45°/+45° is the weakest.
