Locking the movement on an electrical motor
Hello there!
I'm an electrical engineer and I just mounted a new machine on my industrie. It's composed of a motor turning a shaft. This turn is made when the operator press a button. But due to the inertia of the shaft, when the motor stop spinning, the shaft make a half of a turn. And this is caused by the fact that the motor does not have a break.
This inertia was not taked into account when I was making the project for this improvement, but I want to fix it without changing the motor. Is there a way to do this? An electrical or mechanical one?
I don't know if it's necessary, but here's the project that was implemented.
Best regards.
Gustavo
Best regards.
Gustavo
RE: Locking the movement on an electrical motor
A large clutch-brake assembly on the drive from the gear reduction to the shaft. This will stop and hold the shaft and allow the motor to coast down, without driving the shaft.
One successful application of this solution has been alligator shears used to cut re-bar. One clutch-brake that I serviced was air pressure operated.
It may be cheaper to replace the motor with a motor with a brake.
Many years ago we wold have plugged the motor to a stop. (momentary DOL reversing).
Plugging worked well with "U" frame motors, but when "T" frame motors came in, plugging went out.
You may consider using an auto-transformer and plugging at reduced voltage.
Comparing the cost of an auto-transformer, a reversing starter and a plugging switch or timer to de-energize when the motor stops, a new motor may be cheaper and have less failure modes.
Bill
"Why not the best?"
Jimmy Carter
Gunnar Englund
www.gke.org
http://www.warnerelectric.com/products/brake-produ...
And because it appears that English is a second (or 3rd, 4th, etc.) language for you, here is today's free lesson:
Break = the act of making something broken.
Brake = the act of stopping something.
It's important not to break something when trying to brake something...
" We are all here on earth to help others; what on earth the others are here for I don't know.
" -- W. H. Auden
Bill
"Why not the best?"
Jimmy Carter
Gunnar Englund
www.gke.org
Check with the motor maker to see if they offer a brake for the motor. You may be able to get them to replace just the motor and not pay for a new gearbox.
I looked at clutch-brake assemblies; even if they are cheaper than changing the motor, the mounting and additional installation expense will probably be more costly.
Example, no affiliation, not a recommendation: http://www.warnerelectric.com/products/clutch-brak...
There is always a measurable time to stop.
With electrical braking, plugging, Dc injection or other means the stop time is often measured in revolutions to stop.
I have worked on mechanical brakes where the stop time may be measured in a few degrees.
Then there is the Saw Stop System where the time to stop/retract is claimed to be one millisecond, once!
But not instantly.
https://www.youtube.com/watch?v=E3mzhvMgrLE
Bill
"Why not the best?"
Jimmy Carter
Are you desperate for the motor to stop really quickly whenever the operator releases the button (in which case, you're looking for one of the things that are being discussed above) or are you actually more interested in making the shaft stop in the right place (in which case, what you really want is a decent control system).
A.
3DDaves the system is new. All components that was installed are new. I don't think that there's an worn on the gearbox. You said to install a clutch between the motor and the shaft, but I'm using a chain to connect then. The clutch will be installed on the shaft?
zeusfaber, in fact what I want is to make the shaft stop as soon as the operator release the button. More degrees it takes to stop, more problems I'll have.
Putting the brake on the higher speed shaft is often the most effective.
If you need faster stopping, you may add a clutch between the motor and the brake.
Bill
"Why not the best?"
Jimmy Carter
Your picture looks like a worm drive. Have you worked out the inertias of your system? If if is a worm drive, t is possible that most of your system inertia is your motor.
Regardless of how you stop your system, it won't stop instantly. If you decelerate hard to a stop, you will impose high stresses, and something likely will break. What you need to do is stop the system at a predictable rate. If you decelerate at a known, constant rate, you can work out when to start decelerating.
JHG
So the problem here is to avoid the system to rotate to the contrary.
That is a common solution to coasting, with and without brakes on many cranes.
Bill
"Why not the best?"
Jimmy Carter
How frequently is this stopping action required? Also, you have begun using the word "contrary," something you never mentioned in the OP or for a while since...
Is there actually some momentary reverse rotation in the opposite direction you are trying to eliminate?
If there is but it's always by the same amount, the operator can learn to anticipate it and switch off the power supply at the correct instant required to achieve the desired final positioning. [Admittedly this could become problematic if the coasting time constant is so great that a lot of time is wasted while the machine comes to rest, reverses, then finally settles in the right spot.]
If there is and it's never by the same amount twice, a mechanical brake is a virtual necessity, IMHO, since in that situation such anticipation is impossible and therefore unreasonable to expect.
Providing all of the pertinent information right from the outset can save everyone so much time...
CR
You may chose to install a brake on the final hoisting shaft. A brake on the final shaft will have to handle much more torque and will be much larger and more expensive.
If you build another similar system, consider using a final reduction gear that has a hole in the final gear so that it may be mounted directly onto the final hoisting shaft.
This avoids the cost of chain and sprockets and, more importantly, avoids the possibility of a broken chain dropping the load.
Bill
"Why not the best?"
Jimmy Carter
" -- W. H. Auden
You can try 12 Volts and then 24 Volts. If you get decent results and determine the best voltage to use you can then spend the money on a suitable DC supply.
Bill
"Why not the best?"
Jimmy Carter
jraef, the spin that the gearbox do is kind of a lot. Don't know if a backlash can be responsible for all that.
I think that an electromagnetic brake will be the solution.
With DC injection you may use a higher current DC to provide a rapid stop and then drop to a lower level DC current to let the backlash unwind slowly. A timer should be adequate. X seconds at higher current and then Y seconds at lower current.
Bill
"Why not the best?"
Jimmy Carter
1) Automatic detection of the motor emf being zero before applying DC. This is missing on cheap units and leads to failure of the DCIB.
2) Automatic shut off when the motor has stopped. Cheap ones don't have that or just use a timer and that can cause unnecessary added thermal stress to the motor.
" -- W. H. Auden
If that is the case an electric bake or switching to a worm gear drive gearbox is the only solution.
Not likely applicable in this case. Presented just in case it provides inspiration.
[EDIT] Here's an example (cued-up at 12s in): https://www.youtube.com/watch?v=MIYJnd2X9eU&t=...
There are table saws that stop when you stick your finger in the blade. I am not sure this is good for the table saw. I am not willing to test one.
JHG
https://en.wikipedia.org/wiki/SawStop
-AK2DM
"It's the questions that drive us"
Dan - Owner
http://www.Hi-TecDesigns.com
Bill
"Why not the best?"
Jimmy Carter
And hey, nice camera work!
Keith Cress
Now I'm been down the Sawstop rabbit hole. Lots of anger and dismay about that company for their legal dealings.
Activation of the capture mechanism releases the axle, allowing the blade (and mechanism) to drop from the table. I cannot recall if there is a spring, as well, but the blade drops quickly, so I imagine there is.
Dan - Owner
The first project that I worked on was a re-and-re of major substations in a refinery. This was way back in the mid 70's so some of the details are a bit fuzzy. But I do recall installing dc-injection braking modules on cooling tower fans. These modules were to prevent a stopped fan from running backwards due to backdraft caused by adjacent fans running. The modules were also used to provide anti-condensation heat in the stator winding, which is a bonus in such a damp environment. These modules were built by Allen Bradley, but I haven't seen any since the late 70's. (I'm sure that Others can provide a similar solution).
Is there any chance of installing an ASD? A 4-quadrant ASD (ie active FE) would be the ultimate solution, but any ASD can be fitted with a braking resistor. Any ASD could be made to work, plus you get the usual advantages of having an ASD in-situ. An ASD option might even be less expensive than monkeying around with an electric brake.
GG
"I have not failed. I've just found 10,000 ways that won't work." Thomas Alva Edison (1847-1931)
Oh, is that a Hotdog? I thought that this guy had had an accident and now thinking about how to re-attach his pinky.
Gunnar Englund
www.gke.org
FYI: I was just perusing a few VFD manufacturer web-sites and discovered that many of their products come (standard) with braking systems using dc-current-injection. Check out the Yaskawa and Toshiba web-sites. Depending on the motor size, this might be less expensive that trying to retrofit an electro-mechanical brake to an existing system.
GG
