standard parts
standard parts
hi everyone,
herewith i have the problem while creating standard parts having large no.of variants.I have tried with part families,.KRX file,deformable component.but i am facing problem to make fool proof design.is there any another methodology to design such parts?go through the attachment for example part.I am using using NX8.5 and NX10.
thanks in advance,
saikumar.
thanks in advance,
saikumar.
RE: standard parts
You need to make a top level assembly part with all the expressions that control your child parts from the top down. Your spread sheet should have a minimal number of controlling variables. NOT every single one or it will overwhelm the dialogue. Keep it simple.
Use "if" statement expressions in that top level assembly to control the rest of your variable dimensions. Link each child part to its appropriate controlling expression.
Done.
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX9, Win 7 Pro SP1
RE: standard parts
