Insert/curve/text with attribute
Ha All,
When i'm in the modelling mode of NX11.02 i'd like to add a text on a surface. I select the face and edge manually.
I like to reference a part attribute already listed in the attribute list.
Now the question is: how do I reference a part attribute instead of a expression? (it seems I can only select a expression)
Kind regards,
Lars
Kind regards,
Lars
Lars
NX11.0.1.11 native
Solid Edge
Inventor
RE: Insert/curve/text with attribute
-Dave
NX 9, Teamcenter 10
www.nxjournaling.com
when I try the thing you mention above still nog part attributes are showing? I've added the "TEST" attribute within the properties dialog.
How do I make a new expression that references the "TEST" attribute. I can only make a new expression ?
Lars
NX11.0.1.11 native
Solid Edge
Inventor
Is it possible to load all attributes into the expression list at once?
Lars
NX11.0.1.11 native
Solid Edge
Inventor
-Dave
NX 9, Teamcenter 10
I wrote (in fact Cowski) wrote a journal which creates 3 part attributes out of the file name. These are; , "document number" "revision number" and "title"
I use these attributes to fill the title block of the draft.
I did use expressions first to fill the title block but the "update for external reference" takes to long.
Now when is start using expressions again is have to use the "update for external reference" again :(
Maybe it's best to make the expressions in the same journal as the attributes are made?
I use these expressions to make a curve text for engraving sheet metals.
Lars
NX11.0.1.11 native
Solid Edge
Inventor
