Selection of multi-pin connector for power lead cables
I have 6 cables. Each cable has 3 wires: zero, phase, earth.
Each cable supplies 320W 230VAC heater (I have 6 heaters).
I am looking for 1 multi pin connector for all these cables for quick plug in/out.
Link to example connectors:
https://www.aliexpress.com/cheap/cheap-multi-pin-c...
I wonder how many pins my connector must have. I have 18 wires in 6 cables (6xZero, 6xPhase, 6xEarth).
Does it mean that I need at least 18 pin connector or can I have the earth wires connected together?
Also I have calculated that each heater draws approx. 1.4A (320W, 230VAC). Therefore, when I multiply 1.4A by 6 heaters my amperage is 8.4A. Sellers state the amperage for the multi pin connector. I understand that this is maximum load that the connector can take?
In my case should I then look for minimum 10A connector?
Please help.
Please help.
RE: Selection of multi-pin connector for power lead cables
Thank you for your answer.
The heaters are controlled separately through the PLC. Each heater requires separate wires.
Dan - Owner
http://www.Hi-TecDesigns.com
