SAP OAPI with MATLAB : for design result
hi
I wrote the following code to compare the design results.
My goal is to choose the best level.
But in matlab the following error is displayed.
Can someone help me?
CODE
FrameName = NET.createArray('System.String',NumberItems);
MyOption = 1;
Location = NET.createArray('System.Double',NumberItems);
ErrorSummary = NET.createArray('System.String',NumberItems);
WarningSummary = NET.createArray('System.String',NumberItems);
NumberItems = 3;
TopCombo = NET.createArray('System.String',NumberItems);
TopArea = NET.createArray('System.Double',NumberItems);
BotCombo = NET.createArray('System.String',NumberItems);
BotArea = NET.createArray('System.Double',NumberItems);
VmajorArea = NET.createArray('System.Double',NumberItems);
TLCombo = NET.createArray('System.String',NumberItems);
TLArea = NET.createArray('System.Double',NumberItems);
TTCombo = NET.createArray('System.String',NumberItems);
TTArea = NET.createArray('System.Double',NumberItems);
Ret = Analyze.CreateAnalysisModel
DOF = NET.createArray('System.Boolean',6);
for i = 1 : 6
DOF (i) = true();
end
Ret = Analyze.GetActiveDOF(DOF)
Ret = Analyze.RunAnalysis();
View.RefreshView();
if Ret ~= 0
disp('!Add beam object View.RefreshView')
end
%% Design
disp('Design')
DesignConcrete = ...
NET.explicitCast(SapModel.DesignConcrete,'SAP2000v19.cDesignConcrete');
View = NET.explicitCast(SapModel.View,'SAP2000v19.cView');
Ret = DesignConcrete.SetCode('ACI 318-11')
Ret = DesignConcrete.StartDesign
View.RefreshView();
if Ret ~= 0
end
[ret,NumberItems, FrameName,...
Location, TopCombo, TopArea, BotCombo, BotArea, VmajorCombo, VmajorArea, TLCombo, TLArea, ...
TTCombo, TTArea, ErrorSummary, WarningSummary] = ...
DesignConcrete.GetSummaryResultsBeam(', NumberItems, FrameName,...
Location, TopCombo, TopArea, BotCombo, BotArea, ...
TTCombo, TTArea, ErrorSummary, WarningSummary,SAP2000v19.eItemType.Group);
if Ret ~= 0
disp('! Error at Design concrete.GetSummaryResultsBeam ')
end
for i=1:5
if (TopArea(i)<= 0.08 & TopArea(i)>= 0.01)
TopArea(i+1) >= TopArea(i)
end
end[/color]
But for this line:
The error below shows
[color #4E9A06]Message: Index was outside the bounds of the array.
Source:
HelpLink: Thanks
