HDPE Pipe Standard and Test Pressure
Experts,
Which standard used for calculate the TEST Pressure for HDPE pipe(SHOP HYDRO) and How to calclate it?.
For Example : 63 mm OD PN 16 SDR 11 HDPE PIPE.
REGARDS,
G.SRIRAM.
Dream,Dream,Dream Dream transforms in to thoughts.And thoughts result in action
REGARDS,
G.SRIRAM.
RE: HDPE Pipe Standard and Test Pressure
http://www.performancepipe.com/en-us/ind/pages/eng...
https://plasticpipe.org/pdf/tn-46-guidance-field-h...
Unlike steel pipe you have consider pressure rebound.
Dik
Thank u for the stuff.
REGARDS,
G.SRIRAM.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
