parts list in nx9
parts list in nx9
parts list in nx9
When placing a parts list on a drawing, even thought the initial callout is set to 1 and the increment is set to 1, the initial callout is 10 and the increment is 10; I cannot figure out how to correct this. Also, the piece number, or item number, sequence is random (60, 10, 30, 40, 70, etc instead of 1, 2, 3, etc).
RE: parts list in nx9
It will be the way the default parts list is set. Setting in preferences will not fix it. You need to create a new parts list template to use, that is set for your preferences.
Our video shows how to make parts list templates: https://vimeo.com/album/3065578/video/106565338
Anthony Galante
Senior Support Engineer
NX3 to NX11 with almost every MR (24versions)
If you are connected to Teamcenter, the numbering may be drawn from there.
