Amada FO-3015 - Alarm 2154 - sensing alarm
I have just started getting this alarm in the middle of running a sheet of parts. My manual says, "If you get this alarm, CONTACT AMADA" along with every other alarm in the book. Does anybody know what is actually failing in the machine that causes this alarm? I would rather not call in the tech guys.
When I clear the alarm and restart my part, It will cut for about an inch, pick up the head, then try again. I does this about 3-4 times then will give me the alarm again.
Please help.
Please help.
RE: Amada FO-3015 - Alarm 2154 - sensing alarm
are you talking about the z-wire? I have an external one already, it seems as though when i raised my nozzle gap it stopped with the errors.
With the trace off, light on, the cone/nozzle should not follow your finger up and down.
Alt parts is where we order most of our amada service parts
