Steel stair stringer
I am doing a design of a steel stringer . there is two PFC supporting precast concrete treads. According to code requirement i used 4kpa live load on tread.so point load on stringer say 1.5KN. my question is do we need to consider a situation where all the treads are full of 4kpa . so in stringer each and every point which connects to tread having point loads . is that correct or which way need to think? if anyone post an idea that would be helpful.
RE: Steel stair stringer
Parallel Flange Channel.
Thaidavid
The channels we use in the US (typically) have tapered flanges. Not sure if anyone uses PFC's here or how extensively they're used worldwide.
Maybe I'm mistaken that MC's are not used often. I hardly use them but others can chime in or say otherwise.
Like much of the world uses the metric system...except the US
Edit: Oh yeah, I meant to also say something relative to OP's question. In the US, we need to design the entire horizontal projection with 100 psf [4.8 kPa]. Each tread also has to be designed for a single point load of some magnitude (can't think of it right now; I'm thinking either 300 lbs [1.33 kN] or 1000 lbs [4.45 kN]). That point load is applied at center for bending check and at the end for shear check.
Juston Fluckey, SE, PE, AWS CWI
Engineering Consultant
Nearly all men can stand adversity, but if you want to test a man's character, give him power. Abraham Lincoln
Further I need to clarify something. I need to design a base plate for newel post in this stair . as per the attached sketch i use 4 bolts for the connection. is it require this newel post exactly be in middle or any arrangement as per my sketch is ok?
