fixing a steel console with only 2 anchors?
I have to fix a steel console into existing RC beam. Console is supporting a steel canopy beam.
Since RC beam is 250/300 mm I m very limited about how to destribute anchors. I have to consider minimum edge spacing from the edge of concrete and between anchors. So I came up with this:
Normally Id use more than single line of anchors, but in this case forces are small so I think it is OK. Calculations shows that 2 anchors are more than sufficient bu I still feel somewhat uneasy because I have only a single line of anchors. Id add another line but since RC beam is only 300 mm high, I have a problem with steel beam since it shouldnt be too high above the RC beam.
RE: fixing a steel console with only 2 anchors?
Professional Engineer (ME, NH, MA) Structural Engineer (IL)
American Concrete Industries
https://www.facebook.com/AmericanConcrete/
Anchors are M12 (HILTI HST3)
Do you see any mistake in my calculation?
The beam is so much stiffer than the supporting angle.
I missed the question; a single line of anchors would be fine... and your e might be 15mm. If you can imagine the force in the bolt (not the anchors)... if you think the bolt will be in tension from the loading...
Dik
Another possible configuration is to anchor a bent plate to the face of the concrete beam, where the top horizontal leg of the bent plate bears on top of the beam and is anchored through the top of the beam, in addition to the side anchors.
n3jc is accounting for prying. That's where the tension comes from.
I also still haven't seen anything from OP that they checked combined shear breakout of the two bolts, this close to a free edge and combined with tension load I can almost guarantee that this is being overlooked.
Use a WT shape (maybe a fabricated shape) in place of your angle bracket, as bones206 suggests. This way you can get two lines of anchors into the RC beam in more favorable locations.
I would strongly urge you to heed TME's comments regarding concrete shear breakout however. That's likely the governing failure mode and is really the numerical means of determining whether or not one line of fasteners is sufficient.
Edit: It looks like you've overestimated your anchor's shear capacity.
Brian C Potter, PE
Simple Supports - Back at it again with the engineering blog.
I wouldn't take the moment arm e as 60 mm as was noted above. Closer to the end of the bracket is conservative and likely more realistic. I also wouldn't take the moment arm of the compression/tension forces in the anchorage as the full depth. Rather, I'd consider a small rectangular compression block which gives a tension component in the two bolts of around 10.5 kN.
I don't believe you're going to get additional prying loads based on the center stiffener but without knowing your plate thickness I can't be sure. Definitely should be checked regardless.
You noted you're using a wedge anchor but using 1/2" wedge anchors that close to the edge is usually not recommended as the wedge force creates a fairly large bursting force and thus you need something like 80 mm of edge distance or whatever Hilti recommends.
Edit: You addressed this above. I would have also lost a bet. Hilti knows their stuff though so if they say you can do it without bursting the concrete then I'd believe them. Still worth pushing the holes back away from the edge if you can. Just because an expert Hilti installer can avoid cracking the concrete does not mean Joe "Hammer Drill" McMuscles can.
I confirmed that the interaction of concrete breakout in shear and tension definitely controls and I highly suspect your anchoring system will be undersized for the loads you have.
Dik
Brian C Potter, PE
The only "prying" that is in this situation is based on the eccentricity of the vertical load. The tension generated by this eccentric load has been accounted for. I have not verified that their design is correct, but the tension from "prying" is there.
Your sketch implies there is a tension load away from the anchored surface originating between the bolts, but there is none. The tension load is directly at the bolts as a result of the eccentric load.
The deformation shown in your mini-sketch (on the bottom right) cannot occur. The only deformation that can occur is the leg of the angle bending just below the joint between the two legs. If anything the bending in the vertical leg of the angle (especially if the stiffener was not there) would force the steel between the two bolts into the concrete surface, not away from it.
See below. I've removed the stiffener to make it more clear.
There is a difference between the tension reaction caused by this scenario and how AISC defines "prying action". While the sketched scenario is "prying" on the bolts, it's not "prying action" as defined by AISC.
"Prying action" is a secondary tension effect cause by plate bending due to a tension load applied directly to the plate element eccentric from a line parallel to and at the centerline of a bolt. See Chapter 9 in the AISC Manual. The scenario we are discussing does not have this tension load and can't have "prying action".
I fully agree that the unstiffened angle that you show doesn't receive any prying action, unless the plate was so flexible that it's actually prying the nut itself (but this would have to be a very large deformation I would imagine).
I agree. Couldn't have drawn it better myself. In my experience, this is the version of prying action that most folks are concerned with in these situations. The center of compression reaction migrates away from the toe of the angle in a manner that is difficult to predict. This is the version of prying for which I like the stiffener.
TME's version of prying is also legitimate when the stiffnener is in play although I doubt much would come of it for most conventional geometries.
So you've got two kinds of prying potentially. And neither is textbook AISC prying so they're rather difficult to assess. All good reasons to try to detail the issue away as has been suggested several times above.
The horizontal leg of the angle will prevent any meaningful bending that could create "prying action". This situation is similar to the "thick" plates defined in AISC design guide 4 that allow you to ignore "prying action". Once the connecting element is stiff enough, horizontal "prying action" can be ignored.
That's why WT's used to bolt members with tension loads are such a problem, no horizontal leg to stiffen the plate.
Koot,
For the same stiffness reason above, I don't think there is any meaningful two way action. Just the tension load generated from the T/C lever.
jayrod,
Yes they may be thinking that but my original comment was responding to someone saying OP's calc didn't account for prying. I was saying they did account for it. Then the rest of this conversation was based on TMH's next comment specifically about the AISC-defined "prying action"
Dik
Regardless, that doesn't generate "prying action" since the ledger doesn't bend in the horizontal direction.
Dik
Far more critical is the edge distance.
The bolts are always in tension. I don't think anyone is saying they aren't.
What does the tip deflection have to do with prying action in the horizontal plane??
Dik
FYI- the bolts can't just be finger tight. They're wedge anchors so without tightening they don't work.
I'm going to stick with my conclusion of no prying action in the horizontal plane because of the stiffness of the angle in that plane. The only forces on these bolts are shear and tension from the eccentric load (via T/C lever arm). No secondary "prying action."
Dik
What I still dont understand is: why is there so much talking about value e - distance from beam action on angle to edge of the RC beam? As far as I know If I choose larger value of e, the larger eccentricity is which means larger moment and larger tension forces in bolts... So why so much talk about e being closer to the RC beam? e being larger means being more conservative - being on the safe side right?
I use e as a distance between half of a contact surface between a steel beam and steel angle and edge of RC beam
I want to ask another question in a case of 2 lines of bolts as shown below.
What is your opinion about lever arm r1 = 80 mm and r2 =80 + 80 = 160 mm.
Would you consider rotation at the bottom of RC beam or higher? What if there was no stiffener but just an angle? would you consider the same? I think it all depends on plate thickness of steel angle.
For small scale applications like this, I'll assume the point of rotation (neutral axis) to be right at the upper anchor with a triangular compression stress block projecting downwards. That's a physical impossibility, of course, but I feel that it's nicely conservative and it takes me five minutes. In that case, I'll either ignore the lower anchors or assume that they only participate in shear.
In all the hubbabaloo over the taxonomy of the particular kind of prying action we have here, I fear that we may have lost sight of what is some very wise and time honored wisdom: turn the angle leg upwards if you can, as others have recommended above. Do that because:
1) It greatly reduces the need for the stiffener.
2) It moves your anchors to a more favorable location for shear breakout, probably eliminating the need for two rows.
3) It keeps your center of concrete compression pretty reliably near the angle heel reducing that source of non-AISC "prying".
4) It eliminates the non-AISC prying associated with the heel of the angle drifting over laterally (P-delta effectively).
These are all good things when it comes to developing a simple, reliable connection.
That being said, I think assuming that it's acting at the edge is appropriate and conservative when you have a stiffener.
tnx for replies/help!
regards
Dik
