Vulcraft Tekla Plugin
Hello! I have a problem with Vulcraft Jjoist Plugin for Tekla(http://vulcraft.com/bim-technology/tekla). I have installed it on several computers, but it works only on few of them. All computers have the same Tekla version, environment & material catalogs. When I run this plugin it puts only two points start & end, but doesn’t create any profile. When I open Tekla session log I can read the next.
F1 and Shift+F1 are not valid accelerators.
ASSERT: 16.08.2017 16:21:22 REASON: (!"chk_check_object(object)"), File: fun_objects.cpp, Line: 86
Does anybody have any idea, what it means? Maybe someone had the same trouble?
