Plant loads on retaining wall
Can anyone give me any guidance or point me in the right direction to how vertical plant loads are transferred laterally to a retaining wall. I have a 9 tonne drill rig with a 50kN extraction force and track dimensions of 1.5m x 0.25m. I can only find guidance in standards for uniform surcharges. Does anyone know a book or any document that will help me transfer these loads on to the retaining wall?
RE: Plant loads on retaining wall
You could just apply the load for the full width of the active wedge behind the wall. Based on 25KN/track equals a bearing pressure of 67kPa. Thats a high surcharge, typically we adopt 10-20KPa for construction traffic, but if you can make that work without it being uneconomical then why not. Its more conservative and the calcs are easier.
On the topic of the applied bearing pressure, i wouldnt go working out the applied bearing pressure yourself (even though its relatively easy). Anytime we design working platforms for drill rigs etc we were always supplied that info from the contractor. Just covers your ass more tbh.
What type of wall is it? How high and whats the soil type? More info = better responses.
