Multi pin connector for TCKs
I have 6 K type TCKs connected to the machine component.
Component with TCKs is frequently dismantled from the machine for refurbishment.
I am lookimg for some quick 'plug in/out' connector/connection for these TCKs.
Is there any thing like this avaialble?
I can find multi-pin connectors for e.g. lead wires but I am not sure about TCKs (could not find in the web)
Please help.
Thank you.
Please help.
Thank you.
RE: Multi pin connector for TCKs
There are mini plug and jack, widely used on handheld calibrator instruments with flat pins, smaller size.
There are commercial jack panels:
Google thermocouple plug jack
thermocouple jack panel
Thnk you for this tip.
I will check the TCK jack panel.
In search for multi pin connectors dedicated to the TCKs I have came across the following products, which in case someone would look for them may find these links useful:
http://www.omega.co.uk/pptst/MTC_CONN.html
http://www.omega.com/temperature/pdf/JPCB_TJPCB_RJ...
http://www.omega.co.uk/pptst/MJP.html
http://www.omega.co.uk/pptst/TL_SL_BSJ.html
http://www.omega.co.uk/pptst/SM_SUB-D_CONN.html
http://www.omega.co.uk/subsection/thermocouple-ass... (high temperature conductive paste)
https://www.digikey.com/product-detail/en/omron-au...
http://marlinmfg.com/products/connectorsStripanels...
