heat transfer of sorts
Hello all,
I need to calculate water out temperature.
What I know:
Water Temperature in = 70 degrees F
Size of drilled hole through a block = .242" diameter
Pressure of water at inlet = 100 PSI
Temperature of block = 500 degrees F
Length of block = 5.542"
Opening in opposite side of block is open to air
Is there any way to calculate this?
Is there a calculator out there for this sort of calculation?
This is for inside a casting mold.
Wayne
What I know:
Wayne
RE: heat transfer of sorts
TTFN (ta ta for now)
Assuming 5.5 in square area and distance of 2.5 in, the heat flow to 70F surface from 1280 F surface is only 18kW, which suggests that the water will initially steam, until it drives the surrounding material down below boiling point, and the water eventually will run around 76 F.
Lots of assumptions made, possibly erroneously. You'll need a decent thermal FEA to get a better answer.
