STRESS RANGE ASME B.31.3
HI,
I have this problem to share.
I have a line to test, with operating temp uguals -150 / +20, and design temp equals -180 / +200,
in paragraph 319.3.1, ASME, expresses the concept of max metal temp and min metal temp, while in appendix S, uses the operating temp..
witch temp I use for stress range?
-150 + 20
or
-180 +200 ?
in the first case the delta is 170 c in other case is 380 c.
thanks
D
-150 + 20
or
-180 +200 ?
thanks
D
RE: STRESS RANGE ASME B.31.3
