GRP Pipe UG Hydro test
reference from AWWA M45 or any other standard based on which we can eliminate field hydro test,
and which points need to consider to eliminate field hydro test...
like joints need to be check with filed joint tester...
Gravity line (3 Bar) Sea Water Intake and Outfall line for power plant with lager dia. more than DN3600...
