What could make a motor not achieve full RPM's?
Howdy all, Some of you may have read my post from a few days ago regarding a schematic I needed. Well, I'm still working on that same motor. I haven't found the schematic specifically meant for this motor, but I think I have found enough general ones that apply to be dangerous. Anyway, I've been messing around with this motor for a couple-three days now. This motor is a Delco, 3/4 horse, 115/230 volt, 1 PH, 1725 RPM, thermal protected I believe and capacitor start (it's got a start cap on it anyway). There are a total of 5 leads that I can switch around for high or low voltage. Here's the problem, I believe I have identified low and high voltage connections. However I can only get 900 RPM according to my hand held tach. Mysteriously, that is half of the proper RPM. Perhaps that's coincidence, but it seems to be a clue to me. Just to eliminate doubt, I checked my air compressor and bench grinder with the tack and they were right on the money. I have disassembled the motor to see how it's wired inside and ohm things out. Here's what I found. There is a stand-off inside the connection box that is connected to the cap. The other side of the cap connects to a winding, the other end of the winding connects to the centrifical switch which is then connected to another stand-off. I believe this is the start winding circuit. The start winding itself is around 2.5 ohm's. Ok, now there are two other sets of wires. Each pair of wires connects to it's own seperate winding. Both of those windings are around 1.5 ohm's each. I am guessing those two are the run windings. Here's ultimately what I have done. I have unwired the run windings from the start circuit and thermal overload (which has a total of three lugs). Then I connected the two run windings in parallel. Then I spun the motor by hand (remember, no start circuit wired in right now) and applied 115 volts to the run windings. The motor spins ok, but it doesn't seem to get up to speed. I noticed the motor has somewhat of a vibration. Being dumbfounded I connected the run winding in series and tried the experiment again just because. This time the motor would not continue running on it's own wired this way with 115 volts (which makes sense). Mechanically it seems to spin freely. I even oiled the bushings. As far as my eye can tell, no bent shaft. Would a bent shaft prevent full RPM's anyway? I even powered each run winding individually. Both times it tried to run, but just didn't quite have enought to keep going. It performed the same for both windings individually. None of the windings are grounded to the case or each other. Non of them "appear" burnt or shorted. Sorry about the long post, but this is really bugging me. Anyone want to take a shot at this one? I can accept the fact the motor may be junk, but why? I need to know for my one peace of mind. Thanks in advance for any thoughts.
RE: What could make a motor not achieve full RPM's?
Not trying to be an idiot, but:
1)
Try the motor connected in the proper fashion witout any load connected to it. You may have a compressor problem.
2)
Contact DELCO direct. They do not want problems any more than you do.
David
Won't argue with that.
Looks good so far.
Good here.
Here is what you need to try. Swap the leads of one winding and see how it runs!
Let us kow how she runs now.
The most logic explanation is that this motor is hooked up as an 8 pole motor.It could be that your motor may very well be a 2 speed motor(900/1800) which is a pretty common.If the applied voltage was wrong,most likely it would blow fuses or trip breakers.
GusD
DKB1943: Is your statement about cap aging a general statement for all types of construction (metalized film, polypropylene, etc.), or are some types better than others in this regard?
thanks in advance for any feedback . . .
Typically, two speed spa pump motors I see every day have two separate run windings.
Lets assume the motor in question has 2 run windings, that means there must be 8 leads brought out to enable dual voltage operation and thats before start windings, switches etc.
Making a two speed motor DUAL voltage complicates it too much. It leaves the door open for a winding to be connected low voltage and have circulating currents in one winding while the motor runs in the other.
Another consideration is the operating conditions of the capacitor, a 115 volt machine requires 4 times the capacitance of a 230 volt machine. This is overcome by connecting the start circuit to the mid point of the run circuit when connected for the higher voltage ensuring the voltage in the start circuit remains at 115. One thing is for sure, its going to be complicated inside the terminal box!
Not too difficult here ... the motor ALWAYS starts on HIGH speed regardless of if it is powered to the low speed. Stacked contacts on the centrifugal switch insure this!
