Rectangular plate under loading pins
While 4-bending tests on a sandwich we got Identation to avoid that we use a small rectangular plate under loading pins.
can this affect the outcome of the Test?
Thank you
RE: Rectangular plate under loading pins
and at which size is pins small or large?
it is a formula for minimum area to avoid indentation
"An Introduction to Sandwich Construction" by Dan Zenkert Page 111
