Minimum crossing witdth for HDD
in case i want to execute a river crossing using HDD system, is anybody aware of any limitations on the minimum width of the river to use this technology or it depends only from the elastic bending radius of the pipe?
Filippo
Filippo
RE: Minimum crossing witdth for HDD
Depending on pups size practical pipe entry angle could be 5 to 6 degrees otherwise bend height is too big tob feed the pipe in.
My guess is min 10m entry to exit
