Shear Wall - Column Connection in ETABS
When I Model a Shear Wall in Etabs and at both end of the shear wall I model a Column, After Running The Analysis and see the design of the Columns I notice that always I have a High Percentage of rebar needed for the columns, is it normal that the columns play the role here as boundary elements for the wall? or is it wrong to model the columns connected to the shear wall ?
RE: Shear Wall - Column Connection in ETABS
It's actually more efficient this way since you're utilizing the column bars, which are farther out from the NA of the wall, in the lateral load combinations.
