PLS CADD spanish criteria file
Hi. I´m new at using PLS CADD. I can't find any criteria file with spanish code for loads in the version of the program I have. Could anyone send me the proper criteria file or should I have to créate it from de begining?
Thanks.
Thanks.
RE: PLS CADD spanish criteria file
I was at the last User's Group meeting and there were Engineers from all over the world there. You might more help if you post the question in the group "Transmission structure engineering" because the T-Line stuff probably belongs there instead of a General Engineering topic. T-Lines are definitely a very special topic.
_____________________________________
I have been called "A storehouse of worthless information" many times.
