Seamless and welded tubes
Hi all,
I was told by a friend that:
1) Only seamless tube is allowed for superheaters, regardless of temperature. According to him, all types of welded tubes are not allowed for superheaters. I know carbon steel ERW SA178 is used for medium and low-pressure boiler, but I also noticed some ERW low alloy tubes have some creep resistant properties, such as SA-250 T22 (1Cr-0.5Mo,) so it's possible to be used for superheaters.
2) The maximum allowable pressure to use the welded tube is 60 bar, because of more than that, there's a risk of seam tearing.
Thanks for your help.
Aida
Aida
RE: Seamless and welded tubes
Example
SA-178, Electric‐Resistance‐Welded Carbon Steel and
Carbon-Manganese Steel Boiler and Superheater Tubes
SA-250, Electric‐Resistance‐Welded Ferritic Alloy‐Steel
