Fatigue data of counterbored bolts in shear - steel
All,
Does anyone have a reference for the fatigue behaviour of bearing-type bolted joints in a counterbored hole? Main loading is shear alternating between zero and a design value. I imagine there is quite the stress raiser at the edge of the bore. This is for a steel freight car.
Thanks!
tg
Thanks!
tg
RE: Fatigue data of counterbored bolts in shear - steel
Not a lot.
Our other option is switching to counter-sunk fasteners. Assuming this remains a bearing-type connection, does anyone have opinions/references for:
1) Static strength (bearing strength) design equations
2) Fatigue strength of such a connection
My guess is that any fatigue success will be achieved through a friction type (slip-critical) connection instead of bearing type. In this case, is there any guidance on clamp loads for bolts with counter-sunk heads?
tg
Is there an approved, tracked, possibly high strength flat head fastener out there? I have specified phillips socket screws for aircraft hardware.
If you clamp the bolts down hard, there should be minimal fatigue of the bolts. If your bolts are not tightened down hard, your joint is doing all sorts of weird things, all of which you must take into account.
If your flat head screws are driven into tapped holes, you have no allowance for positional tolerances on your holes. Your screws are being bent to line up, which must affect stresses and fatigue. If you have a nut and a large enough clearance hole, this is not an issue.
JHG
