HEAT WATER IN TANK - USING HELICAL TUBE COIL
Hi heat transfer gurus
i want to heat water in a tank with a helical tube coil...
what calculatins are required.
the tank water volume of 1500 liters is at 20 degC
and is to be raised or heated up to 60 degC.
i want to heat all the water in 1 hour.
boiler water at 80 degC at 1 liter/sec will pass
through the helical tube coil and exit at 60 degC.
any spreadsheet or formulas to do this and to work
out the coil surface area & size of tube.
pumpmanplee
pumpmanplee
RE: HEAT WATER IN TANK - USING HELICAL TUBE COIL
Heat Exchanger Design Handbook has a section on Helical Coils. Also J.S. Jayakumar has articles on this subject.
Batch heating expressions are also in Perry Chem Engg Handbook.
