Task Pane blank...
Task Pane blank...
did anyone had an issue having task pane blank? Also I do have installed toolbox, but due to issue with task pane I do not have an access to Toolbox Fasteners. What to do to resolve and if there is no solution, what is way around to insert toolbox fasteners without task pane access? In the attachment is photo of how task pane looks like.
RE: Task Pane blank...
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum PoliciesCAD Systems Manager
Evapar
www.evapar.com
if it happens next time I am going to try that. I tried to uninstall and reinstall, but issue was still present. Then I uninstalled it, then went to registry and manually deleted every single key related to the SolidWorks. After reinstalling the issue was gone.
Regardless, thanks for help.
