4GD Workset Assembly Arrangement connect to Modeler Subassembly Assembly Arrangement?
Is there any way to draw a connection between a 4GD Workset Assembly Arrangement & a Modeler Subassembly MDLPRT that has ten, individual Assembly Arrangements?
Are these Assembly Arrangements each exclusive to the individual Application, or can they communicate?
The dialog boxes look exactly alike in 4GD and Modeler Applications.
VisMock loads the ten Assembly Arrangements from Structure Manager by opening the Subassembly as the 'parent item', then View/Set each Arrangement and load each to a seperate instance inside VisMock, but I can't seem to get 4GD to see the Modeler Assembly Arrangements.
