TP with or without a Diameter Symbol
How I've been working with GD&T for 5 years and not understood this like I thought I did is beyond me but our GD&T guru is out until next week so he cant explain it to me.
Say I've got a slot with a TP of the entire feature of 0.5mm at MMC back to the datums. How is it measured differently if a diameter symbol is in front of the 0.5 vs. if it isn't?
RE: TP with or without a Diameter Symbol
The situation you describe would be what's called a boundary interpretation. Forget the axis or center plane idea: the tolerance zone takes on the same shape as the nominal slot, but with a zone offset toward the inside (air) by 0.25 mm. So the slot can move around, as long as no portion of the physical slot walls violate the protected boundary (which is the virtual condition, in case you're familiar with that term).
If you have the ASME Y14.5 standard, your situation is shown in Figure 7.34.
John-Paul Belanger
Geometric Learning Systems
either replace it with profile (and no Ø is needed)
OR make it two directional (and also no Ø needed)
-profile for form and size
and
-position for location (Fig 8.24/2009) (also no Ø needed)
He rightly gives Fig. 8-24 as an example of that. Profile is used there for form/size and that's good because it would be cumbersome to tolerance the size with traditional methods. But I think a slot is a simple enough geometry where you can use traditional ways of dimensioning the size, and just have one position callout for the boundary location.
John-Paul Belanger
What you said about single position FCF applied to the slot is true and directly supported by the Y14.5-2009 [para. 7.4.5.1(c)], but that still does not change the fact that the diameter symbol in front of the position tolerance value does not make sense.
Read the first sentence of my first post. Once I established that plain fact, the rest of my statements on this thread had to do with the boundary idea.
John-Paul Belanger
Of course, you did not say anywhere that the diameter symbol would be appropriate. My point was that your comment about OP's sketch did not emphasize the inappropriateness again and that your disagreement with greenimi could be taken by OP as a green light for usage of the diameter symbol.
My apologies if I am mistaken.
Tunalover
Electro-Mechanical Product Development
UMD 1984
UCF 1993
John-Paul Belanger
Consider a regular round hole with a position tolerance at MMC. Now suppose the designer intended for a cylindrical tolerance zone, but forgot to include the diameter symbol. See attached graphic for the example.
Normally we might think that this is incorrect, but since the standard nudges us toward a boundary interpretation, and the hole's nominal geometry is cylindrical, then the attached graphic seems to have the same meaning with or without the diameter symbol.
I appeal to Y14.5 paragraph 7.3.3.1, and its subparagraph(a) for my thinking on this.
John-Paul Belanger
I was thinking of the attached example where position and profile of a surface are used together. The position, however, is without the diameter symbol.
Tunalover
UMD 1984
UCF 1993
Be wary of that direction in reasoning. Would the default be a hexagonal tolerance zone for position on a hexagon or a square zone for a square?
Think Figure 7-34, but change the shape of the part to your hexagon. So the answer to your question would seem to be yes.
John-Paul Belanger
Tunalover
UMD 1984
UCF 1993
John-Paul Belanger
The zones for those features are not the same as the boundaries. See Figure 7-29.
One might look to figure 8-24, but it's a bad example. Had the item in figure 8-24 been a square or a rectangle there would be more than the given amount of shift allowed to the opening along the diagonal. It substituted a position tolerance with ambiguous interpretation for a composite profile with a well defined interpretation. With a diamond, it allows significantly more movement along the longest width.
Then how does one generally control form AND position of irregular features like slots such that the positional tolerance zone is not rectangular?
All the examples I've seen do not provide a general method that provides a cylindrical tolerance zone.
Tunalover
UMD 1984
UCF 1993
John-Paul Belanger
The boundary in 7-34 isn't a correct interpretation of the virtual condition for the feature - it's another reinterpretation of position as if it's a composite profile. The actual boundary cannot have full radius ends. As a result it doesn't match the limitations on position that the mid-plane interpretation gives.
But if I hear you, you're claiming that the only true boundary in Fig. 7-34 is the 12.5 x 6.75 straight-across dimensions (and not the radii)? Their picture sure makes it look like the bumpy radius of an actual slot is restricted from violating a radius boundary of position also.
However, I think that's all irrelevant to the question posed in my graphic, which I still can't get a straight answer on:
A hole is a single, regular FOS (so very different from Fig. 7-34), and if that hole has a position tolerance as I showed (without the diameter symbol), would it be interpreted by the standard as a cylindrical boundary, or rejected as an illegal callout?
John-Paul Belanger
By convention it should be rejected as a typo/spelling error. If the zone is cylindrical it should have a diameter modifier. If it doesn't have the modifier then the zone won't be cylindrical and is undefined.
Look what happens to the boundary when the position tolerance is equal to or larger than the hole, leaving a non-existent or imaginary boundary. This is where the zone interpretation is needed. Where the boundary is existent it needs to match the result the zone allows for.
I'll make an example picture of the reason the example boundaries are incorrect.
Here are some thoughts.
I would question the use of the diameter symbol for anything other than a cylindrical feature. So in LargeNCharge86's drawing, I wouldn't apply the diameter symbol. I agree with J-P that we don't know exactly what would have to be within a cylindrical zone, in other words there is no definition of the "center" of an oblong slot.
J-P,
Your NoDiameter graphic with the cylindrical hole and no diameter symbol is interesting - you may have found a case where Y14.5's rules are not entirely self-consistent. I think that the drawing makes sense and should be legal - the surface interpretation is well defined. Without the diameter symbol, there would be no axis interpretation. However, I would also say that the drawing would likely be misinterpreted - the reader might think that it's part of some kind of bidirectional spec and the other FCF is missing, or that the diameter symbol was unintentionally omitted.
We may need to be more rigorous on terminology here. Where you said "no diameter symbol, so the position zone isn't cylindrical and isn't rectangular", I believe that you meant the position boundary that the surface would have to conform to. But because you used the word "zone", some may have thought you were referring to a tolerance zone that the center geometry would have to conform to.
3DDave,
I see your point about the larger diagonal movement on a square or rectangular shape. This is because of Y14.5's rule that tolerance zone boundaries preserve sharp corners, is that right? Even in Fig. 8-24, the cutout could move further in the direction towards the sharp corner than it could in the direction towards the R10 corner. This is assuming that the cutout doesn't rotate at all. Defining and controlling the "center" geometry of irregular shapes quickly becomes a mess - I don't think that J-P was suggesting this. It's really only possible on regular features of size.
I'm not sure that I fully understand your reference to composite profile in the context of Fig. 7-34. I would agree, though, that the way that the boundary is calculated in 7-34 has some dodgy aspects. Offsetting in by 0.75 on the rads gets rid of some of the material from the flats, so I agree that this relaxes some of the requirement on the centerplane. The oblong slot is a special case that Y14.5 defines and the "blended tolerance" boundary isn't fully defined where the rads meet the flats.
Evan Janeshewski
Axymetrix Quality Engineering Inc.
www.axymetrix.ca
Since the only feature for which a zone vs positional boundary interpretation are identical is circular, it makes sense to eliminate the use for anything except circular features and come up with an alternate, such as limiting the translation of the MMC shape and disallowing encroachment of the LMC shape; basically create an outer offset within which MMC movement is restricted rather than an inner boundary that can become degenerate.
The current position boundary interpretation is identical to the profile composite, supplying a uniform offset that does not restrict changes in position to the tolerance allowed for those features where the profile curvature is greater than the tolerance. To clarify, any sharp corner has infinite curvature; curvature of radii = 1/radius.
Does it still result in the reddish-colored area from your Inkscape graphic? Or would this be interpreted as smoothing out the full boundary to become a slot-shaped reddish zone?
John-Paul Belanger
John-Paul Belanger
Frankly it seems like an academic exercise that doesn't seem applicable to an actual product.
True, it is mostly an academic discussion now. Profile is the go-to control for these irregular shapes.
John-Paul Belanger
AMIN. That I was saying a week ago when this discussion started.
Why using "problematic" callouts (position, Boundary) when a more robust way of defining this feature is already offered by the standard.
