Move assembly component using NX Journal
Hi all,
I'm new to working with the NX Journal tool, and I am trying to write a code that will allow me to move a component within an assembly. I used the record function and currently have a working program. I want to allow the user to pick which component is moved, but of course that cannot be done via the record function.
How can I edit my current program to allow the user to select a part within the active assembly?
NX 7.5//VB.net
RE: Move assembly component using NX Journal
The code below illustrates one way to allow the user to interactively select a component while your journal is running. I think the code will work on NX 7.5, but I no longer have that version installed to test.
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Module componentOriginalPosition
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim sel As Selection = NXOpen.UI.GetUI.SelectionManager
Sub Main()
Dim selectedObjectsArray() As NXObject
SelectComponent(selectedObjectsArray)
Dim pt as Point3D
Dim RotMat as Matrix3x3
Dim pt2 as Vector3D
Dim RotMat2 as Matrix3x3
Dim SelComp(selectedObjectsArray.Length - 1) As NXOpen.Assemblies.Component
SelComp(0) = CType(selectedObjectsArray(0), NXOpen.Assemblies.Component)
SelComp(0).GetPosition(pt, RotMat)
'msgbox("Translation: " & pt.x & ", " & pt.y & ", " & pt.z)
'msgbox("Rotation: " & vbcrlf & _
'	RotMat.xx & ", " & RotMat.xy & ", " & RotMat.xz & vbcrlf & _
'	RotMat.yx & ", " & RotMat.yy & ", " & RotMat.yz & vbcrlf & _
'	RotMat.zx & ", " & RotMat.zy & ", " & RotMat.zz)
'no translation of component on first pass
pt2.x = 0
pt2.y = 0
pt2.z = 0
'transpose of the rotation matrix, undo any rotations on the component
RotMat2.xx = RotMat.xx
RotMat2.xy = RotMat.yx
RotMat2.xz = RotMat.zx
RotMat2.yx = RotMat.xy
RotMat2.yy = RotMat.yy
RotMat2.yz = RotMat.zy
RotMat2.zx = RotMat.xz
RotMat2.zy = RotMat.yz
RotMat2.zz = RotMat.zz
'move the component back to the original rotation
workPart.ComponentAssembly.MoveComponent(SelComp(0), pt2, RotMat2)
'get the translation information again, now that the component has been rotated back to absolute
'negate the translations that have been applied to the component
pt2.x = -pt.x
pt2.y = -pt.y
pt2.z = -pt.z
'set rotation matrix to identity matrix, we want no new rotations on the component
RotMat2.xx = 1
RotMat2.xy = 0
RotMat2.xz = 0
RotMat2.yx = 0
RotMat2.yy = 1
RotMat2.yz = 0
RotMat2.zx = 0
RotMat2.zy = 0
RotMat2.zz = 1
'translate component back to 0,0,0
End Sub
'' The following routine is from GTAC
' sub to select component
Sub SelectComponent(ByRef selectedObjects As NXObject())
  Dim ui As UI = NXOpen.UI.GetUI
  Dim message As String = "Select Component"
  Dim title As String = "Selection"
  Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
  Dim keepHighlighted As Boolean = False
  Dim includeFeatures As Boolean = False
  Dim response As Selection.Response
  Dim selectionAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
  Dim selectionMask_array(1) As Selection.MaskTriple
  With selectionMask_array(0)
    .Type = UFConstants.UF_component_type
    .Subtype = 0
  End With
  response = ui.SelectionManager.SelectObjects(message, title, scope, selectionAction, includeFeatures, _
    keepHighlighted, selectionMask_array, selectedObjects)
  If response = Selection.Response.Cancel Or response = Selection.Response.Back Then
    Return
  End If
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
  GetUnloadOption = NXOpen.UF.UFConstants.UF_UNLOAD_IMMEDIATELY
End Function
End Module
www.nxjournaling.com
