Total Deadhead Pressure of Pumps Operating in Series
I have two pumps operating in series to achieve a higher overall discharge pressure. If a valve on the discharge line is closed, both pumps will deadhead. My question is whether the net pressure in the piping downstream of the pumps (upstream of valve obviously) will be the sum of the deadhead pressure of the two pumps or only the deadhead pressure of the higher pressure pump? Why?
RE: Total Deadhead Pressure of Pumps Operating in Series
Why? Because the pumps are adding differential head to the fluid so what head enters the second pump is the discharge head of the first pump.
Any details or background here??
the pressure will be =pump1 + pump2 + downstream ( it could be a tank head ) , and the reason is becuase because in this case you are dealing with closed system , which every thing will add up .
to proove this theory check the downstream PSV set preasure and you will find out that it will be equal to all of the dead head pressures of all related equipments and vessels .
regards
as for the calculation :
1/ pumps pressure shall be found in performance curve at zero flow.
2/ tank pressure shall be calculated by density*head*9.81 , lines sizes can be neglected.( note that suction nozzle is almost 1 meter from the ground if you need very conservative calculation you shall subtract it from total head , depending on the pump suction level from the ground)
regards
thanks littleinch for the remark , actually i didnt notice above process diagram .
any way yes as you said , and even for more precise calculation the filter manufacturer should give approximate value for the filter discharge factor or the filter minimum head loss , and subtract it from the total pressure .
after you try this calculation try to check any close by downstream PSV and check its set point to clarify .
regards
