3d meshing with two touching solid bodies in MSC Marc Mentat
I'm working on this concrete beam with rebar going through it. These are all solid bodies the problem I believe is where the rebar touches the concrete. I believe Marc sees those elements as not 3d. Thanks for any help or suggestions.
RE: 3d meshing with two touching solid bodies in MSC Marc Mentat
disclaimer: all calculations and comments must be checked by senior engineers before they are taken to be acceptable.
