Butt Joint Weld Questions
I'm hoping someone can help me with some confusion I have on welds. Let's say I have a butt joint between equal thickness plates and the welding process is SMAW. I want to avoid CJP and I'd like to weld from one side, so I'm considering one of 3 options between B-P1c, BC-P2, and BTC-P4, as shown on pages 8-52, 8-53, and 8-55 of the AISC Manual 14th edition, respectively.
Let's say I have 1/4" thick plates, the largest Weld Size (E) I can get out of each is:
B-P1c:
Weld Size (E) = T1/2 = 1/4" /2 = 1/8"
BC-P2:
f = 1/32" min
S = 1/4" - 1/32" = 7/32"
Weld Size (E) = S = 7/32"
BTC-P4:
f = 1/8" min
S = 1/4" - 1/8" = 1/8"
Weld Size (E) = S - 1/8" = 0"
Let's say I have 5/16" thick plates, the largest Weld Size (E) I can get out of each is:
B-P1c:
N/A, not permitted for thickness over 1/4"
BC-P2:
f = 1/32" min
S = 5/16" - 1/32" = 9/32"
Weld Size (E) = S = 9/32"
BTC-P4:
f = 1/8" min
S = 5/16" - 1/8" = 3/16"
Weld Size (E) = S - 1/8" = 1/16"
First of all, is my understanding of these tables and the equations correct? If so, here's my confusion:
Why is BTC-P4 weaker than B-P1c? In both situations the plates are butted up against one another and welded, but one has a bevel. Intuitively I would think any bevel would provide better weld strength than no bevel.
Also, while I understand why BC-P2 is stronger than PTC-P4, why is it by such a large margin? In 5/16" thick plates BC-P2 is 4.5 times stronger than BC-P2, and in 1/4" plates BTC-P4 provides zero strength, which I also find hard to believe.
My ultimate goal is to specify a non-CJP weld that can be done from a single side that provides reasonable strength while minimizing unnecessary fabrication.
As it stands, it seems that I should be specifying B-P1c for 1/4" plates and thinner, and BC-P2 for plate thicknesses of 5/16" and thicker. BTC-P4 just doesn't seem to have a place until you get to much thicker plates such as 1/2" where the weld size would be at least half that at 1/4". I just don't like that I have to add the fabrication cost of beveling both plates, I wish I could use just one bevel but these tables and equations suggest I get little to no strength out of that. So if I have a 5/16" plate, am I really stuck beveling both plates?
I hope all of this makes sense. This isn't for a specific project or anything, I'm really just looking for general guidance/wisdom on best practices for butt joints like this. Thanks for any help.
B-P1c:
BC-P2:
f = 1/32" min
BTC-P4:
f = 1/8" min
B-P1c:
BC-P2:
f = 1/32" min
BTC-P4:
f = 1/8" min
RE: Butt Joint Weld Questions
