Combine 2 Journals
Combine 2 Journals
Below are 2 Journals to be Run In NX9. Can someone help me to combine[/b].
Journal #1 Journal Number 1 puts a PDF in Teamcenter
Option Strict Off
Imports System
Imports System.IO
Imports System.Collections
Imports System.Windows.Forms
Imports System.Windows.Forms.MessageBox
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Sub Main
Dim dwgs As Drawings.DrawingSheetCollection
dwgs = workPart.DrawingSheets
Dim sheet As Drawings.DrawingSheet
Dim i As Integer
Dim pdfFile As String
Dim currentPath As String
Dim currentFile As String
Dim exportFile As String
Dim partUnits As Integer
Dim strOutputFolder As String
Dim strRevision As String
Dim rspFileExists
Dim rspAdvancePrint
'determine if we are running under TC or native
Dim IsTcEng As Boolean = False
Dim UFSes As UFSession = UFSession.GetUFSession()
UFSes.UF.IsUgmanagerActive(IsTcEng)
partUnits = displayPart.PartUnits
'0 = inch
'1 = metric
If IsTcEng Then
currentFile = workPart.GetStringAttribute("DB_PART_NO")
strRevision = workPart.GetStringAttribute("DB_PART_REV")
Else 'running in native mode
'currentFile = GetFilePath() & GetFileName() & ".prt"
currentPath = GetFilePath()
currentFile = GetFileName()
Try
strRevision = workPart.GetStringAttribute("REVISION")
strRevision = Trim(strRevision)
Catch ex As Exception
strRevision = ""
End Try
End If
exportFile = currentFile
strOutputFolder = OutputPath()
'if we don't have a valid directory (ie the user pressed 'cancel') exit the journal
If Not Directory.Exists(strOutputFolder) Then
Exit Sub
End If
strOutputFolder = strOutputFolder & "\"
rspAdvancePrint = MessageBox.Show("Add advance print watermark?", "Add Watermark?", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
Dim shts As New ArrayList()
For Each sheet in dwgs
shts.Add(sheet.Name)
Next
shts.Sort()
i = 0
Dim sht As String
For Each sht in shts
If sheet.name = sht Then
i = i + 1
If rspAdvancePrint = vbyes Then
pdfFile = strOutputFolder & exportFile & "_advance" & ".pdf"
Else
If strRevision <> "" Then
pdfFile = strOutputFolder & exportFile & "_" & strRevision & ".pdf"
Else
pdfFile = strOutputFolder & exportFile & ".pdf"
End If
End If
'the pdf export uses 'append file', if we are on sheet 1 make sure the user wants to overwrite
'if the drawing is multisheet, don't ask on subsequent sheets
If i = 1 Then
If File.Exists(pdfFile) Then
rspFileExists = msgbox("The file: '" & pdfFile & "' already exists; overwrite?", vbyesno + vbquestion)
If rspFileExists = vbYes Then
Try
File.Delete(pdfFile)
msgbox(ex.message & vbcrlf & "Journal exiting", vbcritical + vbokonly, "Error")
Exit Sub
End Try
Else
'msgbox("journal exiting", vbokonly)
Exit Sub
End If
End If
End If
'update any views that are out of date
theSession.Parts.Work.DraftingViews.UpdateViews(Drawings.DraftingViewCollection.ViewUpdateOption.OutOfDate, sheet)
Try
ExportPDF(sheet, pdfFile, partUnits, rspAdvancePrint)
Catch ex As exception
msgbox("Error occurred in PDF export" & vbcrlf & ex.message & vbcrlf & "journal exiting", vbcritical + vbokonly, "Error")
Exit Sub
End Try
Exit For
End If
Next
Next
If i = 0 Then
MessageBox.Show("This part has no drawing sheets to export", "PDF export failure", MessageBoxButtons.ok, MessageBoxIcon.Warning)
Else
MessageBox.Show("Exported: " & i & " sheet(s) to pdf file" & vbcrlf & pdfFile, "PDF export success", MessageBoxButtons.ok, MessageBoxIcon.Information)
End If
End Sub
Function GetFileName()
Dim strPath As String
Dim strPart As String
Dim pos As Integer
'get the full file path
strPath = displayPart.fullpath
'get the part file name
pos = InStrRev(strPath, "\")
strPart = Mid(strPath, pos + 1)
strPath = Left(strPath, pos)
'strip off the ".prt" extension
strPart = Left(strPart, Len(strPart) - 4)
GetFileName = strPart
End Function
Function GetFilePath()
Dim pos As Integer
GetFilePath = strPath
End Function
Function OutputPath()
'Requires:
' Imports System.IO
' Imports System.Windows.Forms
'if the user presses OK on the dialog box, the chosen path is returned
'if the user presses cancel on the dialog box, 0 is returned
Dim strLastPath As String
Dim strOutputPath As String
'Key will show up in HKEY_CURRENT_USER\Software\VB and VBA Program Settings
Try
'Get the last path used from the registry
strLastPath = GetSetting("NX journal", "Export pdf", "ExportPath")
'msgbox("Last Path: " & strLastPath)
Catch e As ArgumentException
Catch e As Exception
msgbox (e.GetType.ToString)
Finally
End Try
Dim FolderBrowserDialog1 As New FolderBrowserDialog
' Then use the following code to create the Dialog window
' Change the .SelectedPath property to the default location
With FolderBrowserDialog1
' Desktop is the root folder in the dialog.
.RootFolder = Environment.SpecialFolder.Desktop
' Select the D:\home directory on entry.
If Directory.Exists(strLastPath) Then
.SelectedPath = strLastPath
Else
.SelectedPath = "D:\home"
End If
' Prompt the user with a custom message.
.Description = "Select the directory to export .pdf file"
If .ShowDialog = DialogResult.OK Then
' Display the selected folder if the user clicked on the OK button.
OutputPath = .SelectedPath
' save the output folder path in the registry for use on next run
SaveSetting("NX journal", "Export pdf", "ExportPath", .SelectedPath)
Else
'user pressed 'cancel', exit the subroutine
OutputPath = 0
'exit sub
End If
End With
End Function
Sub ExportPDF(dwg As Drawings.DrawingSheet, outputFile As String, units As Integer, advancePrint As Integer)
Dim printPDFBuilder1 As PrintPDFBuilder
printPDFBuilder1 = workPart.PlotManager.CreatePrintPdfbuilder()
printPDFBuilder1.Scale = 1.0
printPDFBuilder1.Action = PrintPDFBuilder.ActionOption.Native
printPDFBuilder1.Colors = PrintPDFBuilder.Color.BlackOnWhite
printPDFBuilder1.Size = PrintPDFBuilder.SizeOption.ScaleFactor
If units = 0 Then
printPDFBuilder1.Units = PrintPDFBuilder.UnitsOption.English
Else
printPDFBuilder1.Units = PrintPDFBuilder.UnitsOption.Metric
End If
printPDFBuilder1.XDimension = dwg.height
printPDFBuilder1.YDimension = dwg.length
printPDFBuilder1.OutputText = PrintPDFBuilder.OutputTextOption.Polylines
printPDFBuilder1.RasterImages = True
printPDFBuilder1.ImageResolution = PrintPDFBuilder.ImageResolutionOption.Medium
printPDFBuilder1.Append = True
If advancePrint = vbyes Then
printPDFBuilder1.AddWatermark = True
printPDFBuilder1.Watermark = "ADVANCE PRINT NOT TO BE USED FOR PRODUCTION " & Today
Else
printPDFBuilder1.AddWatermark = False
printPDFBuilder1.Watermark = ""
End If
Dim sheets1(0) As NXObject
Dim drawingSheet1 As Drawings.DrawingSheet = CType(dwg, Drawings.DrawingSheet)
sheets1(0) = drawingSheet1
printPDFBuilder1.SourceBuilder.SetSheets(sheets1)
printPDFBuilder1.Filename = outputFile
Dim nXObject1 As NXObject
nXObject1 = printPDFBuilder1.Commit()
printPDFBuilder1.Destroy()
End Sub
End Module
Journal #2 Journal Number 2 puts a PDF out in your Local drive
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.Drawings
Imports NXOpen.PDM
Imports NXOpen.UF
Imports NXOpenUI
Imports NXOpen.UI
Module IR_8957521
Dim theUFSession As UFSession = UFSession.GetUFSession()
Sub Main()
Dim encodedName As String = ""
theUFSession.Part.AskPartName(workPart.Tag, encodedName)
'Echo("Part Name: " & encodedName)
Dim psStat As PartSaveStatus = workPart.Save(BasePart.SaveComponents.False,
BasePart.CloseAfterSave.False)
' decode the part name
Dim pNum As String = ""
Dim pRev As String = ""
Dim pfType As String = ""
Dim pfName As String = ""
theUFSession.Ugmgr.DecodePartFileName(encodedName, pNum, pRev, pfType, pfName)
'Echo(pNum)
'Echo(pRev)
'Echo(pfType)
'Echo(pfName)
'Echo("Part name: " & encodedName)
' Create candidate name for the PDF
Dim pdfName As String = pNum & "_" & pRev & "_" & "PDF"
'Echo("pdfName: " & pdfName)
' Ask user to verify the name for the PDF
pdfName = NXInputBox.GetInputString("Verify or Change PDF Name:", _
"***** PDF NAME *****", pdfName)
' Get rid of existing PDF
MsgBox("If " & pdfName & " exists, please delete it before proceeding.",
MsgBoxStyle.OkOnly)
' Get all of the sheets in the part
Dim sheetList() As DrawingSheet = workPart.DrawingSheets.ToArray()
Dim sheetCount As Integer = sheetList.Length()
Echo("Count of Drawing Sheets: " & sheetCount)
If sheetCount.Equals(0) Then
MsgBox("There are no Drawing Sheets.", MsgBoxStyle.Critical)
Return
End If
' Create the builder
' Set the other builder options
printPDFBuilder1.Relation = PrintPDFBuilder.RelationOption.Specification
printPDFBuilder1.DatasetType = "PDF"
printPDFBuilder1.NamedReferenceType = "PDF"
'printPDFBuilder1.Size = PrintPDFBuilder.SizeOption.ScaleFactor
printPDFBuilder1.DatasetName = pdfName
printPDFBuilder1.XDimension = sheetList(0).Length
printPDFBuilder1.YDimension = sheetList(0).Height
printPDFBuilder1.Action = PrintPDFBuilder.ActionOption.New
printPDFBuilder1.NamedReferenceType = "PDF_Reference"
Echo("Sheet # 0 Validate? " & printPDFBuilder1.Validate().ToString())
' Make a new PDF from the first sheet
Dim sheets1(0) As DrawingSheet
sheets1(0) = sheetList(0)
If sheetCount.Equals(1) Then
Return
End If
' Append the rest of the sheets
For inx As Integer = 1 To sheetCount - 1
printPDFBuilder1.XDimension = sheetList(inx).Length
printPDFBuilder1.YDimension = sheetList(inx).Height
printPDFBuilder1.Action = PrintPDFBuilder.ActionOption.Append
sheets1(0) = sheetList(inx)
Echo("Sheet # " & inx & " Validate? " & printPDFBuilder1.Validate().ToString())
Next
End Sub
Sub Echo(ByVal output As String)
theSession.ListingWindow.Open()
theSession.ListingWindow.WriteLine(output)
theSession.LogFile.WriteLine(output)
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
Return Session.LibraryUnloadOption.Immediately
End Function
End Module
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
Sub Main
Dim i As Integer
Dim rspFileExists
Dim rspAdvancePrint
'0 = inch
'1 = metric
If IsTcEng Then
Try
strRevision = ""
End Try
End If
Exit Sub
End If
Next
shts.Sort()
i = 0
Dim sht As String
i = i + 1
Else
Else
End If
End If
If i = 1 Then
Try
Exit Sub
End Try
Else
Exit Sub
End If
End If
End If
Try
Exit Sub
End Try
Exit For
End If
Next
Next
If i = 0 Then
Else
End If
End Sub
Dim pos As Integer
End Function
Dim pos As Integer
End Function
'Requires:
' Imports System.IO
Try
Finally
End Try
Else
End If
Else
OutputPath = 0
'exit sub
End If
End With
End Function
If units = 0 Then
Else
End If
Else
End If
End Sub
End Module
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.PDM
Imports NXOpen.UF
Imports NXOpenUI
Imports NXOpen.UI
Module IR_8957521
Sub Main()
'Echo(pNum)
'Echo(pRev)
'Echo(pfType)
'Echo(pfName)
MsgBoxStyle.OkOnly)
Return
End If
Return
End If
Next
End Sub
End Sub
End Function
End Module
RE: Combine 2 Journals
What this new journal have to do?
With best regards
Michael
Journal #2 puts a PDF out on your Local Drive under a folder or any folder you want.
I want to run these two Journals as one...Objective: Turn two BUTTONS into One Button.
What I see in code is that You changed the order - 1st puts PDF in folder and the 2nd in TC. I'm not familiar with TC, because we don't use it. Could You send some movie how this process runs? What I see in 1st journal - it can detect, if you're in TC or native. Also in the 2nd You have: encodedName, pNum, pRev, pfType, pfName are they important?
Please run this code, and write yours results.
CODE
Option Strict Off Imports System Imports System.IO Imports System.Collections Imports System.Windows.Forms Imports System.Windows.Forms.MessageBox Imports NXOpen Imports NXOpen.UF Module NXJournal Dim theSession As Session = Session.GetSession() Dim theUFSession As UFSession = UFSession.GetUFSession() Dim workPart As Part = theSession.Parts.Work Dim displayPart As Part = theSession.Parts.Display '********************************************************** Sub Main Dim dwgs As Drawings.DrawingSheetCollection dwgs = workPart.DrawingSheets Dim sheet As Drawings.DrawingSheet Dim partUnits As Integer 'determine if we are running under TC or native Dim IsTcEng As Boolean = False Dim UFSes As UFSession = UFSession.GetUFSession() UFSes.UF.IsUgmanagerActive(IsTcEng) partUnits = displayPart.PartUnits If IsTcEng Then msgbox("Teamcenter: yes") Else 'running in native mode msgbox("Teamcenter: no") End If End Sub Public Function GetUnloadOption(ByVal dummy As String) As IntegerReturn Session.LibraryUnloadOption.Immediately End Function
End Module With best regards
Michael
This is an as is combine
So if the original journals works so this will work
CODE -->
Option Strict Off Imports System Imports System.IO Imports System.Collections Imports System.Windows.Forms Imports System.Windows.Forms.MessageBox Imports NXOpen Imports NXOpen.UF Imports System.Collections.Generic Imports NXOpen.Drawings Imports NXOpen.PDM Imports NXOpenUI Imports NXOpen.UI Module NXJournal Dim theSession As Session = Session.GetSession() Dim workPart As Part = theSession.Parts.Work Dim displayPart As Part = theSession.Parts.Display Dim theUFSession As UFSession = UFSession.GetUFSession() '********************************************************** Sub Main Dim dwgs As Drawings.DrawingSheetCollection dwgs = workPart.DrawingSheets Dim sheet As Drawings.DrawingSheet Dim i As Integer Dim pdfFile As String Dim currentPath As String Dim currentFile As String Dim exportFile As String Dim partUnits As Integer Dim strOutputFolder As String Dim strRevision As String Dim rspFileExists Dim rspAdvancePrint 'determine if we are running under TC or native Dim IsTcEng As Boolean = False Dim UFSes As UFSession = UFSession.GetUFSession() UFSes.UF.IsUgmanagerActive(IsTcEng) partUnits = displayPart.PartUnits '0 = inch '1 = metric If IsTcEng Then currentFile = workPart.GetStringAttribute("DB_PART_NO") strRevision = workPart.GetStringAttribute("DB_PART_REV") Else 'running in native mode 'currentFile = GetFilePath() & GetFileName() & ".prt" currentPath = GetFilePath() currentFile = GetFileName() Try strRevision = workPart.GetStringAttribute("REVISION") strRevision = Trim(strRevision) Catch ex As Exception strRevision = "" End Try End If exportFile = currentFile strOutputFolder = OutputPath() 'if we don't have a valid directory (ie the user pressed 'cancel') exit the journal If Not Directory.Exists(strOutputFolder) Then Exit Sub End If strOutputFolder = strOutputFolder & "\" rspAdvancePrint = MessageBox.Show("Add advance print watermark?", "Add Watermark?", MessageBoxButtons.YesNo, MessageBoxIcon.Question) Dim shts As New ArrayList() For Each sheet in dwgs shts.Add(sheet.Name) Next shts.Sort() i = 0 Dim sht As String For Each sht in shts For Each sheet in dwgs If sheet.name = sht Then i = i + 1 If rspAdvancePrint = vbyes Then pdfFile = strOutputFolder & exportFile & "_advance" & ".pdf" Else If strRevision <> "" Then pdfFile = strOutputFolder & exportFile & "_" & strRevision & ".pdf" Else pdfFile = strOutputFolder & exportFile & ".pdf" End If End If 'the pdf export uses 'append file', if we are on sheet 1 make sure the user wants to overwrite 'if the drawing is multisheet, don't ask on subsequent sheets If i = 1 Then If File.Exists(pdfFile) Then rspFileExists = msgbox("The file: '" & pdfFile & "' already exists; overwrite?", vbyesno + vbquestion) If rspFileExists = vbYes Then Try File.Delete(pdfFile) Catch ex As Exception msgbox(ex.message & vbcrlf & "Journal exiting", vbcritical + vbokonly, "Error") Exit Sub End Try Else 'msgbox("journal exiting", vbokonly) Exit Sub End If End If End If 'update any views that are out of date theSession.Parts.Work.DraftingViews.UpdateViews(Drawings.DraftingViewCollection.ViewUpdateOption.OutOfDate, sheet) Try ExportPDF(sheet, pdfFile, partUnits, rspAdvancePrint) Catch ex As exception msgbox("Error occurred in PDF export" & vbcrlf & ex.message & vbcrlf & "journal exiting", vbcritical + vbokonly, "Error") Exit Sub End Try Exit For End If Next Next If i = 0 Then MessageBox.Show("This part has no drawing sheets to export", "PDF export failure", MessageBoxButtons.ok, MessageBoxIcon.Warning) Else MessageBox.Show("Exported: " & i & " sheet(s) to pdf file" & vbcrlf & pdfFile, "PDF export success", MessageBoxButtons.ok, MessageBoxIcon.Information) End If 'j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2 Dim encodedName As String = "" theUFSession.Part.AskPartName(workPart.Tag, encodedName) 'Echo("Part Name: " & encodedName) Dim psStat As PartSaveStatus = workPart.Save(BasePart.SaveComponents.False, BasePart.CloseAfterSave.False) ' decode the part name ' ==================== Dim pNum As String = "" Dim pRev As String = "" Dim pfType As String = "" Dim pfName As String = "" theUFSession.Ugmgr.DecodePartFileName(encodedName, pNum, pRev, pfType, pfName) 'Echo(pNum) 'Echo(pRev) 'Echo(pfType) 'Echo(pfName) 'Echo("Part name: " & encodedName) ' Create candidate name for the PDF ' ================================= Dim pdfName As String = pNum & "_" & pRev & "_" & "PDF" 'Echo("pdfName: " & pdfName) ' Ask user to verify the name for the PDF ' ======================================= pdfName = NXInputBox.GetInputString("Verify or Change PDF Name:", _ "***** PDF NAME *****", pdfName) ' Get rid of existing PDF ' ======================= MsgBox("If " & pdfName & " exists, please delete it before proceeding.", MsgBoxStyle.OkOnly) ' Get all of the sheets in the part ' ================================= Dim sheetList() As DrawingSheet = workPart.DrawingSheets.ToArray() Dim sheetCount As Integer = sheetList.Length() Echo("Count of Drawing Sheets: " & sheetCount) If sheetCount.Equals(0) Then MsgBox("There are no Drawing Sheets.", MsgBoxStyle.Critical) Return End If ' Create the builder ' ================== Dim printPDFBuilder2 As PrintPDFBuilder printPDFBuilder2 = workPart.PlotManager.CreatePrintPdfbuilder() ' Set the other builder options ' ============================= printPDFBuilder2.Colors = PrintPDFBuilder.Color.BlackOnWhite printPDFBuilder2.Relation = PrintPDFBuilder.RelationOption.Specification printPDFBuilder2.DatasetType = "PDF" printPDFBuilder2.NamedReferenceType = "PDF" printPDFBuilder2.Scale = 1.0 'printPDFBuilder2.Size = PrintPDFBuilder.SizeOption.ScaleFactor printPDFBuilder2.OutputText = PrintPDFBuilder.OutputTextOption.Polylines printPDFBuilder2.Units = PrintPDFBuilder.UnitsOption.English printPDFBuilder2.RasterImages = True printPDFBuilder2.Watermark = "" printPDFBuilder2.DatasetName = pdfName printPDFBuilder2.XDimension = sheetList(0).Length printPDFBuilder2.YDimension = sheetList(0).Height printPDFBuilder2.Action = PrintPDFBuilder.ActionOption.New printPDFBuilder2.DatasetType = "PDF" printPDFBuilder2.NamedReferenceType = "PDF_Reference" Echo("Sheet # 0 Validate? " & printPDFBuilder2.Validate().ToString()) ' Make a new PDF from the first sheet ' =================================== Dim j2_sheets1(0) As DrawingSheet j2_sheets1(0) = sheetList(0) printPDFBuilder2.SourceBuilder.SetSheets(j2_sheets1) Dim j2_nXObject1 As NXObject j2_nXObject1 = printPDFBuilder2.Commit() printPDFBuilder2.Destroy() If sheetCount.Equals(1) Then Return End If ' Append the rest of the sheets ' ============================= For inx As Integer = 1 To sheetCount - 1 printPDFBuilder2 = workPart.PlotManager.CreatePrintPdfbuilder() ' Set the other builder options ' ============================= printPDFBuilder2.Colors = PrintPDFBuilder.Color.BlackOnWhite printPDFBuilder2.Relation = PrintPDFBuilder.RelationOption.Specification printPDFBuilder2.DatasetType = "PDF" printPDFBuilder2.NamedReferenceType = "PDF" printPDFBuilder2.Scale = 1.0 'printPDFBuilder2.Size = PrintPDFBuilder.SizeOption.ScaleFactor printPDFBuilder2.OutputText = PrintPDFBuilder.OutputTextOption.Polylines printPDFBuilder2.Units = PrintPDFBuilder.UnitsOption.English printPDFBuilder2.RasterImages = True printPDFBuilder2.Watermark = "" printPDFBuilder2.DatasetName = pdfName printPDFBuilder2.XDimension = sheetList(inx).Length printPDFBuilder2.YDimension = sheetList(inx).Height printPDFBuilder2.Action = PrintPDFBuilder.ActionOption.Append printPDFBuilder2.DatasetType = "PDF" printPDFBuilder2.NamedReferenceType = "PDF_Reference" j2_sheets1(0) = sheetList(inx) printPDFBuilder2.SourceBuilder.SetSheets(j2_sheets1) Echo("Sheet # " & inx & " Validate? " & printPDFBuilder2.Validate().ToString()) j2_nXObject1 = printPDFBuilder2.Commit() printPDFBuilder2.Destroy() Next 'j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2j2 End Sub '********************************************************** Function GetFileName() Dim strPath As String Dim strPart As String Dim pos As Integer 'get the full file path strPath = displayPart.fullpath 'get the part file name pos = InStrRev(strPath, "\") strPart = Mid(strPath, pos + 1) strPath = Left(strPath, pos) 'strip off the ".prt" extension strPart = Left(strPart, Len(strPart) - 4) GetFileName = strPart End Function '********************************************************** Function GetFilePath() Dim strPath As String Dim strPart As String Dim pos As Integer 'get the full file path strPath = displayPart.fullpath 'get the part file name pos = InStrRev(strPath, "\") strPart = Mid(strPath, pos + 1) strPath = Left(strPath, pos) 'strip off the ".prt" extension strPart = Left(strPart, Len(strPart) - 4) GetFilePath = strPath End Function '********************************************************** Function OutputPath() 'Requires: ' Imports System.IO ' Imports System.Windows.Forms 'if the user presses OK on the dialog box, the chosen path is returned 'if the user presses cancel on the dialog box, 0 is returned Dim strLastPath As String Dim strOutputPath As String 'Key will show up in HKEY_CURRENT_USER\Software\VB and VBA Program Settings Try 'Get the last path used from the registry strLastPath = GetSetting("NX journal", "Export pdf", "ExportPath") 'msgbox("Last Path: " & strLastPath) Catch e As ArgumentException Catch e As Exception msgbox (e.GetType.ToString) Finally End Try Dim FolderBrowserDialog1 As New FolderBrowserDialog ' Then use the following code to create the Dialog window ' Change the .SelectedPath property to the default location With FolderBrowserDialog1 ' Desktop is the root folder in the dialog. .RootFolder = Environment.SpecialFolder.Desktop ' Select the D:\home directory on entry. If Directory.Exists(strLastPath) Then .SelectedPath = strLastPath Else .SelectedPath = "D:\home" End If ' Prompt the user with a custom message. .Description = "Select the directory to export .pdf file" If .ShowDialog = DialogResult.OK Then ' Display the selected folder if the user clicked on the OK button. OutputPath = .SelectedPath ' save the output folder path in the registry for use on next run SaveSetting("NX journal", "Export pdf", "ExportPath", .SelectedPath) Else 'user pressed 'cancel', exit the subroutine OutputPath = 0 'exit sub End If End With End Function '********************************************************** Sub ExportPDF(dwg As Drawings.DrawingSheet, outputFile As String, units As Integer, advancePrint As Integer) Dim printPDFBuilder1 As PrintPDFBuilder printPDFBuilder1 = workPart.PlotManager.CreatePrintPdfbuilder() printPDFBuilder1.Scale = 1.0 printPDFBuilder1.Action = PrintPDFBuilder.ActionOption.Native printPDFBuilder1.Colors = PrintPDFBuilder.Color.BlackOnWhite printPDFBuilder1.Size = PrintPDFBuilder.SizeOption.ScaleFactor If units = 0 Then printPDFBuilder1.Units = PrintPDFBuilder.UnitsOption.English Else printPDFBuilder1.Units = PrintPDFBuilder.UnitsOption.Metric End If printPDFBuilder1.XDimension = dwg.height printPDFBuilder1.YDimension = dwg.length printPDFBuilder1.OutputText = PrintPDFBuilder.OutputTextOption.Polylines printPDFBuilder1.RasterImages = True printPDFBuilder1.ImageResolution = PrintPDFBuilder.ImageResolutionOption.Medium printPDFBuilder1.Append = True If advancePrint = vbyes Then printPDFBuilder1.AddWatermark = True printPDFBuilder1.Watermark = "ADVANCE PRINT NOT TO BE USED FOR PRODUCTION " & Today Else printPDFBuilder1.AddWatermark = False printPDFBuilder1.Watermark = "" End If Dim sheets1(0) As NXObject Dim drawingSheet1 As Drawings.DrawingSheet = CType(dwg, Drawings.DrawingSheet) sheets1(0) = drawingSheet1 printPDFBuilder1.SourceBuilder.SetSheets(sheets1) printPDFBuilder1.Filename = outputFile Dim nXObject1 As NXObject nXObject1 = printPDFBuilder1.Commit() printPDFBuilder1.Destroy() End Sub '********************************************************** Sub Echo(ByVal output As String) theSession.ListingWindow.Open() theSession.ListingWindow.WriteLine(output) theSession.LogFile.WriteLine(output) End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer Return Session.LibraryUnloadOption.Immediately End Function End ModuleRE: Combine 2 Journals
no changes in journal 1 full as is
only variables names changes in journal 2
if the journal run with/without errors.
Because I haven't nxmanager to test!it.
In native its run OK.
CODE
because I've got an error, about TC.
With best regards
Michael
No, because this line as is and the original 2 journals run OK.
If you run it in native you get error in this line.
Thanks.
