Inflatable Seal Design References
I'm looking for any references on how to analyze and design an inflatable seal.
The seal will be an inflatable rubber ring that will be located in an outer groove of a disc which is to seal against the internal diameter of a pipe.
In my research so far I've found many companies that do custom design and fabrication of these things but I haven't found any references on how to actually analyze one.
We have to perform a design check on an existing product, so need to be able to understand how they are typically designed and analyzed.
