PTI Design Method - Only a 40psf Live Load?
I have a question about the PTI Design Method for stiffened slabs on ground (3rd Edition w/ 2008 Supplement).
We do not do post tensioned slabs in our office, but I have heard numerous people say they use the PTI method to calculate design moments and shears. Then they just come up with a conventional reinforcing scheme versus cables. I was hoping to do the same.
Section 4.5.4.1 states that a 40psf uniform live load is assumed over the foundation plus 65psf dead load from an assumed 4in slab.
My question is: What if you want a higher uniform live load such as 100psf for a 1st floor corridor? Or a thicker slab? I’m not seeing how that would get incorporated into any of the design formulas. Only the perimeter loading value can be adjusted.
Thank you.
RE: PTI Design Method - Only a 40psf Live Load?
Probably compensated for in any LLR allowed.
Mike McCann, PE, SE (WA)
