Electric boiler and explosion
Dear All,
I have read that electric boiler are safer than other boilers and some are sold as explosion proof. I would like to know whether this is "sales argument" or reality.
I can see that electric boiler do not have the risk related to storage of flammable fuel, firebox explosion.
But does the problem of cracking of the vessel not remain?
Would a safety valve failure not lead to an explosion, in case the pressure is not properly monitored?
Many thanks in advance
Chris
Chris
RE: Electric boiler and explosion
General Blr. CA,USA
Is this claim expressed in an advertisement ... Or is this something that someone told you
You state: "But does the problem of cracking of the vessel not remain?"
What problem ??? What do you mean ????
Any boiler fired with any fuel can be made to fail if operated above the design pressure and temperature range.
Electric boilers (and water heaters) are niche products sold for niche applications.
They tend to be sold as smaller boilers and are a very expensive source of steam.
MJCronin
Sr. Process Engineer
Previous post quote: "Any boiler fired with any fuel can be made to fail if operated above the design pressure and temperature range."
Yes. this is also what I thought, but I needed confirmation for this.
Chris
General Blr. CA,USA
