Which material is more effected by UV rays?
We currently use a material that has been known to become brittle over time in sunlight. I have been given the material properties for the material and another material that could be a potential alternative. But I'm not sure which property to be interested in to determine it's capability in sunlight to be come brittle over time.
The properties I have been given for both of the materials are as follows:
- Melt Flow Rate (Melt Flow Index)
- Nominal Density
- Flexural Modulus
- Tensile Strength
- Heat Distortion Temperature
Other properties I have been given for just one of the materials or the other:
- Vicat Softening Point
- Flammability Resistance
- Moulding Shrinkage
Would any of these properties help determine the better material for outdoor use in sunlight? If so, which property/properties and would I be looking for a high or low value?
Thanks in advance.
- Nominal Density
- Flexural Modulus
- Tensile Strength
Thanks in advance.
RE: Which material is more effected by UV rays?
www.tynevalleyplastics.co.uk
Politicians like to panic, they need activity. It is their substitute for achievement.
I don't quite grasp how two grades are different for UV stability. They are both PP.
The copolymer will be higher impact strength which may offset UV degradation, but I would like to hear the rationale behind the choices?
Chris DeArmitt PhD FRSC
President
Plastic materials consultant to the Fortune 100
www.phantomplastics.com
We buy in moulded parts of the Homopolymer from a supplier currently to fit to our units which sit outside, and we have heard reports that over time the parts are becoming brittle sitting in the sun. We heard from the supplier that this other material (Copolymer) may be better against UV rays but to be honest, I've tried asking all sorts of questions to the supplier about the properties and they never really answer my questions so I'm not sure how good their knowledge is.
So, thought about putting a tarp over them? Or are they also sitting outside when in use?
President
