Pressure Treating LP LVL Series Joists ???
Is pressure treating (Wolmanizing) LVL joists possible without affecting the strength characteristics?
Or is pressure treating even possible for this product?
If it is possible, anyone know if these joists could be obtained off the shelf, or have you seen such more as a special order item?
I cannot find a specific note to the subject in the LVL catalog... it only mentions applying a resin overlay to protect the members from the elements during construction - "Watershed" Stability Overlay, and it is proprietary - $$$. I would not term this pressure treating...
They do have wolmanized Paralams, but only in the 3.5" width, not for joists.
I have a call into the company, but they are closed for the evening.
Thanks.
Mike McCann, PE, SE (WA)
Thanks.
RE: Pressure Treating LP LVL Series Joists ???
All is good.
Dik
