Saving File in multiple folders using MACRO
Good morning
I am working on a macro that would save my files in two different folders. I know it sounds easy except:
-Folder 1 in the same all the time so this will be easy
-Folder 2 is part of a folder structure we use for each project.
Example of folder structure:
\\User
-Project X
-Work
-PDF
-Images
So I am working on files in the "work" folder and need to save a PDF version of the file in the "PDF" folder.
I managed to go back one level, from "Work" to "Project x" using the following code but I do not know how to go into PDF and save my file there.
CODE --> VBA
FileLocation2 = Left(MyDoc.Path, InStrRev(MyDoc.Path, "\") - 1)
Any help will be much appreciated.
RE: Saving File in multiple folders using MACRO
Hello ferdo
I wrote it in Catvba as I am planning to use it with Office as well.
The interface for picking the path would not be required as they are standard (one is a fixed pathway from start to finish and the other will only be different until inside the project folder.)
I am not sure about using a different environment as I will need to have a clear button inside the software they are using (Catia, PowerPoint, Word) so it is as easy for the user as possible. I would go for a toolbar like yours but they are not very open to big changes. I need to ease them in saving time eliminating specific tasks.
