plan 53b and 53c difference?
dear all,
I'd like to ask you what's the difference between plan 53b and plan 53c, we know that plan 53b has bladder accumulator, what's the function of bladder accumulator?and why use bladder accumulator?
thank you
RE: plan 53b and 53c difference?
Not really sure what information you are looking for.
Like you said the 53b uses a bladder accumulator. The barrier is pressurized using a gas, and this bladder isolates the gas from barrier fluid (unlike a 53a).
The 53c uses a piston accumulator to pressurize the barrier fluid.
Generally you use the bladder if you are pressurising barrier above 10 bar. I believe the 53c piston system is better but costs more
above certain pressure N2 will dissolve in barrier liquid and might cause foaming, therefore separation of barrier gas and barrier liquid by means of bladder/piston
Another complication with a bladderless accumulator is the need to install a level guage and level switch to alert the plant operator to top up, while a bladder type accumulator only needs a pressure guage / pressure switch, which is arguably less prone to failure than a level switch. A bladder type accumulator amy also save you on pressurisation gas for the plan 53b alternate.
[left][i][right]Plan 53C is the most complex, and least standardized of
the three. It is sometimes called a pressure boosting or pressure
intensifying system. It contains moving parts that regulate the
barrier pressure as a function of the pump’s product pressure.
The moving part is a sealed piston pressurized with the pumped
medium. On the other side of the piston, the barrier fl uid is pressurized in a hydraulic cylinder to a pressure that is higher
than the reference or pump pressure. The difference is driven
by the piston ratio in the cylinder. The typical input/output
pressure ratio is 1:1.1 or about a 10 percent increase or boost.
These systems can have an internal cooling coil or an external
cooler in the loop as in Plan 53B. With an internal coil,
their cooling capacity is typically limited to 4 kW. The makeup
volume is typically limited to approximately 1 gallon with a
maximum operating pressure of roughly 1,000 psig. Plan 53C
is typically used in applications where the pressure differential
across the inner seal must be maintained within a narrow range.
Use is limited to clean pumping fl uids since fi ne abrasives may
cause the piston seal to malfunction and the system to fail due
to lost pressure differential. Any leakage of pumped fl uid is
contained within the system.
The greatest benefi t of this system is that no external
energy is required to pressurize the barrier fl uid. Plan 53C systems
require periodic maintenance and, in general, are not as
reliable as Plans 53A or B.
A well phrased question has answers in itself!!!
