How can the material impact test temperature be set in PVElite 2017 ?
Dear All,
I have executed a calculation of a Torospherical head with a blinded welding neck nozzle (Pdesign=1,1 MPa, Tdesign =160 oC) in PVElite 2017.
However the head (SA-516 70) and nozzle (SA-350 LF2) have a calculated MDMT of resp. -6 oC and -29 oC, while -46 oC is required.
These parts are impact tested and I want to enter that in the program so they are exempted of the MDMT check resulting in below warning:
Required Minimum Design Metal Temperature -46 °C
Warmest Computed Minimum Design Metal Temperature -6 °C
I have tried to enter the material impact test temperature in the configuration dialog box but it only shows me the components and no place where I can enter the temperature.
What am I doing wrong ? or am I trying to enter the material impact test temperature in the wrong dialog box ?
Does anyone know ?
Best regards
VesselFred
Does anyone know ?
Best regards
VesselFred
RE: How can the material impact test temperature be set in PVElite 2017 ?
Sorry for the delay.
To set the material on Impact Test on PV Elite, all you have to do is
--> While selecting material there are 3 dots besides its selection.
--> Go for "If normalized or quenched and tempered option" so that your material gets shift to curve D
--> Check the box at the bottom "Has this material been impact tested?"
and there you are with material been impact tested.
Got it and many thanks for that.
What I also need to include as an impact tested material is the reinforcement pad I use for the nozzle.
Where can I indicate that the pad I use (made of SA516-70)is also impact tested ?
If I don't do this I will get a warning that the Computed overall MDMT was higher than the required value !
Appreciate your answer on this one.
Best regards
VesselFred
