Dimension1.GetValue wont work?
Hi Guys,
I have a few bits of script that alter dimensions properties for me.
they work ok on my pc on R18 and I'm sure I have tried them on R21 as well.
When I try them on a work pc running R21 & R24 they come up with
an error "Object doesn't support this property or method Dimension1.GetValue"
any ideas ?
thanks
Alan
any ideas ?
thanks
Alan
RE: Dimension1.GetValue wont work?
In my (1 month and a half) experience I imagine that dimension1 is a wrong object that does not support that method.
For example if I use ".getCoordinates" with a hybridShapeExtremum instead of a point, it gives that error (in my case it happened).
I'm using a machine at another company's and it behaves really odd.
thanks anyway guys :)
I keep looking at the automation file but find info like this.
If i understood what it is actually telling me I wouldnt have to bother you guys so much :(
MyDimension.SetTolerances(iTolType, itolName, iUpTol, iLowTol, idUpTol, idLowTol, DisplayMode)
Could someone please give me an example of how you complete the line?
cheers guys
Not pretty but it kind of works and I'm slowly (very slowly) starting to get the jist of how it works.
But,
Can anyone tell me why I have to run the script twice before it changes everything?
Sub CATMain()
Dim documents1
Set documents1 = CATIA.Documents
Set Document = CATIA.ActiveDocument
Dim selection1
Set selection1 = Document.Selection
Set Info = selection1.Item(1)
Dim Dimension1
Set Dimension1 = Info.Value
Dim DimTolValue
Set DimTolValue = Dimension1
Dim oTolType
Dim oDisplayMode
Dim oTolName
Dim oUpTolS
Dim oLowTolS
Dim oUpTolD
Dim oLowTolD
DimTolValue.GetTolerances oTolType, oTolName, oUpTolS, oLowTolS, oUpTolD, oLowTolD, oDisplayMode
oTolName = "TOL_NUM2"
oUpTolD = 0.2
oLowTolD = -0.0
DimTolValue.SetTolerances oTolType, oTolName, oUpTolS, oLowTolS, oUpTolD, oLowTolD, oDisplayMode
Dim DimDimValue
Set DimDimValue = Dimension1.GetValue
DimDimValue.SetFormatName 1, "ANS.DIMM"
DimDimValue.SetFormatPrecision 1, "0.100" 'precision
Dim oNoOff
oNoOff=InputBox ( "Enter No Off Holes" )
Dim oNoOffText
oNoOffText = "("& oNoOff &"x) "
Dim oBefore
oBefore =oNoOffText
Dim oAfter
oAfter =" THRO'"
Dim oUpper
'oUpper = "Upper"
Dim oLower
'oLower = "Lower"
Dimension1.GetValue.SetBaultText 1, oBefore, oAfter, oUpper, oLower
Dim myDim 'As DrawingDimension
Set myDim = CATIA.ActiveDocument.Selection.Item(1).Value
Dim myDimLine 'As DrawingDimLine
Set myDimLine = myDim.GetDimLine
myDimLine.DimLineGraphRep = catDimLine2Parts
MyDim.RestoreValuePosition()
End Sub
