Macro for hiding Axis and/or planes
Does anybody know where I could retrieve a macro for hiding axis and/or planes? Preferably both. When I bring parts up in TCe it is loaded with them and I don't have the time to individually hide them all.
RE: Macro for hiding Axis and/or planes
I use the search tool(edit>search) or (ctrl f).
Setup your query for axis system (visible) then in the advanced tab select "or", then select plane (visible). The visible option is available if you hit the more button.
Select the search icon (not search and select). Now you can add your query as a favorite.
Once the query has been added as a favorite it will stay with your catsettings.
Now in any file select search / favorites, select your saved query and choose the "search and select" icon.
select hide/show.
You could probably record the steps to a macro, I find hitting ctrl f then favorites is quick enough.
This is for hiding the planes.
CODE --> VBScript
Set productDocument1 = CATIA.ActiveDocument
Set product1 = productDocument1.Product
Set selection1 = productDocument1.Selection
selection1.Search "CatPrtSearch.Plane,All"
Set visPropertySet1 = selection1.VisProperties
visPropertySet1.SetShow catVisPropertyNoShowAttr
selection1.Clear
And you can change the search to do it for the axis.
I have the same issue with a lot of parts.
